Results 1 to 4 of 4
Thread: Grinding Noise from engine...?
    VP S Model
    Apr 2005
    Default Grinding Noise from engine...?
    Hey,
    I have a 92' VP. When im accelerating, there is a loud grinding noise from what sounds like the front of the gearbox, or back of the engine....Feels like its coming from just below the radio console, and maybe a little bit to the front of it. Only happens under acceleration...just sounds like my engine is worn to sh*t...like there is parts of it just broken off and bouncing around...but yeah, only happens under acceleration. Hard to describe, like a loose grinding noise, quite loud...any ideas?
    missus (in more ways than one)
    Sep 2005
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    possibly check the centre hanger bearing ofthe drive shaft, however, when this is worn it normally shows with a vibration which you can feel under your butt. could also possibly be a main shaft bearing in the trans/input shaft bearing?? maybe drain some of the transfluid, does it smell burnt, does it look like their metal shavings in there??
    edit:assuming this is an auto, if its a manual it could be the thrust bearing forthe clutch but would be more apparent when operatingthe clutch. but again drain the box and check the oil for signs of wear/tear
    Vp berlina
    May 2010
    I know no one has been on this thread for a very long while but hopefully someone will see this. My car just started doing this the other day and naturally I haven't driven it since. How much would something like this set me back? I have the car booked into a mechanic next week to fix a weeping fuel tank and if I can get both done at once but without having to get a loan to get it fixed it'd be great lol. Being a student money is certainly hard to come by at the moment
  1. Grinding noise upon braking
    By vn2nv in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-01-2011, 03:03 PM
  2. grinding noise....:(
    By Torquen in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-11-2009, 12:15 AM
  3. VS V6 strange grinding noise.
    By Fitzy3VSVY in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-10-2006, 11:09 AM
  4. VS V6 strange grinding noise.
    By Attakarrak in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-07-2006, 07:59 AM
  5. Strange grinding noise
    By Bec in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-09-2004, 12:18 AM
