Results 1 to 6 of 6
Thread: how do i take off the steering wheel
    91 lexcen vn S2
    Nov 2005
    heathmont
    Default how do i take off the steering wheel
    i dont know how to take off my sttering wheel on my s2 vn lexcen. i can take off the part where you press the horn (actually it was never there) then i can take off the bolts and then this metal plate thing comes off. and the wires for the horn un-attach. then i come across the problem. ther seems to be like this metal circular ring that is welded onto some other thing
    cheers
    matt
    YOU KNOW WHAT THEY SAY.......WAIT......NO I DONT
    VNV6VENGEANCE's Avatar
    VNV6VENGEANCE is offline VeNgeance
    VN Turbo
    Jan 2006
    adelaide,sa
    Once you get past the electrics (horn) there should be a bolt end with a nut on it. If you don't have a gear puller it could prove a real headf*ck as the steering wheels have been on there for a good 18 years. Can you take a pic of what your looking at ..? i've heard of dodgey ways to get the wheel off by smacking the bolt with a rubber mallet to ease the tension but don't do that as it can warp the steering column.
    only good cops a dead cop...
    s1 vn commodore turbo
    t3/t4 front mounted turbo
    Intercooler ---3"exhaust
    stage 2 shift kit---B&M Qicksilver shifter
    3:45 lsd
    18" Cv8z Monaro rims 245's
    NORTI's Avatar
    NORTI is offline come get me
    VR Calais 5L, WM Statesman
    May 2004
    I bought puller, I have a standard one & a Sports one lol, they are less than $15.00 so go buy one, makes things so much easier......
    D.
    91 lexcen vn S2
    Nov 2005
    heathmont
    cheers. when my cam gets fixed, i will post.
    basically, the is like a nut and bolt thing sticking out the front, i can take the bolt off with a spanner and then i got no idea....cheers
    matt
    s0sage's Avatar
    s0sage is offline Posting aimlessly ..
    MX6 - Turbo .... so flame me
    Mar 2005
    just spray some crc or water dispersant or wd40 or whatever lube ya got all around the nut..
    PUT THE NUT BACK ON THE THREAD AT LEAST 5 THREADS ... THE STEERING WHEEL CAN COME FREE AND FLY OFF WITHOUT WARNING ..
    trust me .. i wore a lump on my forhead for days once
    using your palms .. whack around the back of the steering wheel like a clock 1, 2, ,3,4, etc .. just work your way around the wheel . turn the wheel left to right without the car switched on too .. it can help free a sticky wheel.
    basically .. it can be a tough job without a steering wheel puller. but if you persevere with it it WILL come free eventually. i resorted to using a slide hammer on whitevc's vc commy a few weeks back. :P sticky bastard that one.
    never late in a 3 0 .. uhhh ... intercooled turbo
    yes i drive an mx6 turbo ... its probably quicker than yours.
    Stewart1000's Avatar
    Stewart1000 is offline work done by ME
    VL twin turbo. VN5L. old jeep, shit mondeo.
    Sep 2005
    vic
    you take the nut off and then what do you see? it is most likely that the steering wheel is just stuck on, its a very very small clearance so over time they sort of stick themselves together. get a big of steel, cut out 3 holes, one big one in the middle and 2 on the outside, make sure the 2 on the outside line up the the threads on the wheel and the middle with the steering collum, screw some bolts through the outside hole into the wheel and get a long bolt with a nut and put the nut on the steel faceing the wheel and screw it through it from the other side until it hits the colum then keep turning it and it will pull it off. that probably doesnt make sense but give it a shot and it will come together as you go along
    my web site
    stuff on the XF throttle body conversion, calais interior and lots of other junk!
  1. Boss kits for VT steering wheels to fit a VZ/VY steering wheel?
    By nEb. in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-12-2011, 07:28 PM
  2. Steering wheel
    By Johnno.o in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-10-2007, 04:38 PM
  3. steering wheel vq
    By myvq5ltr in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-12-2006, 09:23 PM
  4. Vy Steering Wheel
    By vy1sv8 in forum Parts And Other Items For Sale
    Last Post: 10-08-2006, 10:43 PM
  5. Your thoughts on replacing steering wheel with airbag to a MOMO wheel....
    By *VOLATILE* in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-02-2006, 08:36 AM
