Results 1 to 9 of 9
Thread: Oil leak
    Shortstuff's Avatar
    Shortstuff is offline Random
    1995 VR II V6 Wagon
    May 2006
    Default Oil leak
    I've got a fair bit of oil coming out of this hole in between cylinders 4 and 6. It's just under the level of the rocker cover gasket. You can see it in between the two injectors in the photos. I hadn't noticed it before and wondered if there should be some sort of bung or cover for it? Any help is much appreciated!
    Whoever said 'There is no substitute for cubes' had obviously never heard of Jet power
    holden007 is offline VRII
    Subaru Liberty
    Dec 2003
    VT Berlina & mazda 2 DE
    Jul 2006
    Shortstuff's Avatar
    1995 VR II V6 Wagon
    May 2006
    Rocker cover gasket was changed about a month ago for the roadworthy! Funny thing is, I couldn't see any oil leaks before it was changed. That hole isn't meant to be plugged then?
    VN v6 s2 Berlina 5spd
    Mar 2006
    are you saying it was a series 1 and they blocked the breather on the rocker cover?
    Shortstuff's Avatar
    1995 VR II V6 Wagon
    May 2006
    It is a series 1. The hole isn't blocked up at all though, and is leaking quite a bit of oil. Is that where the breather should go?I suppose it's possible that a pipe was removed when the gasket was done, and not put back.
    crazyspoon05's Avatar
    crazyspoon05 is offline Penguin Whisperer
    The 'Bizta' VNVPVR Wagz
    May 2006
    Mine had same leak but replaced rocker cover gasket and was all good, i looked at all the engines at the wreckers and no cars there had a plug for that hole either, it's just a blind hole that wasn't used for anything with the VN engines...
    VN series II custom :) and VZ exec
    May 2005
    Mildura
    its just a bolt hole, but goes now where, but oil will sit there, on the left side the alternator bracket bolts there i would clean it first, but your manifold could be leaking, or they didnt tighten th bolts up on the rocker covers enough,
    cheers, nick
    Shortstuff's Avatar
    1995 VR II V6 Wagon
    May 2006
    Quote Originally Posted by crazyspoon05
    Ok. Thanks for that. Looks like i'll end up doing the rocker cover gasket again. I'll do it myself this time though!!
  1. Vn Oil Leak :(
    By VNPOWER in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-09-2008, 09:27 AM
  2. oil leak
    By drans_vp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-08-2006, 07:22 PM
  3. V bad oil leak!
    By hotrod32 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-04-2006, 02:08 PM
  4. Oil leak
    By newo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-01-2006, 09:14 PM
  5. Oil Leak
    By paullmichelle in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-10-2004, 10:15 PM
