i just thought id let you all know how much trouble i went through when i did my rear main i would not recomend for any one to do it in place dont be lazy like me and just pull the k-frame off. then have troubles with the auto being in the way.i nearly did my head inand im a mechanic but in the end i got it done it just took about twice the time. i found the leak in the end...... somone had done work on the bottom end and forgot the seal then insted of fixing it had usad selastic to seal the auto dust cover on. F%$^&NG Numb nuts.
well if you want some tips ill be ail to tell you wot not to do hahaha
Stato on the inside, berlina on the out side,5ltr under the bonnet,stockies all round...........that thing has to be a sleeper
MY RIDES
[SIGPIC][/SIGPIC]
http://forums.justcommodores.com.au/...ad.php?t=41837
