Hi all.Wondering if someone has any ideas on my stalling problem.My vn wagon stalls repeatedly when the engine is hot.Say when you go to the shops and get back in and start.When its left to cool its fine,I suppose because the auto choke is working.Any help would be much appreciated![]()
I had the same kinda problem on my lexcen. when it was hot it would cut out and if it was still hot after you had been to the shops etc, it wouldnt start till it cooled down... is this kinda the same? if so its the crank angle sensor, easy way to tell is next time it does this tip cold water over the large pully connected to the crank, slowly tip about 2 - 3L of cold water on the pully if it starts its the sensor. let me know how u go.
