anyone know how to put a vl diff in a vn or what needs to be changed
cheers
vl turbo diffs fit under vn/p..... i dont think any others do but im not positive on that one
you'd be better off taking yours out and getting a mechanic to install the 3:45vl gears.
only good cops a dead cop...
s1 vn commodore turbo
t3/t4 front mounted turbo
Intercooler ---3"exhaust
stage 2 shift kit---B&M Qicksilver shifter
3:45 lsd
18" Cv8z Monaro rims 245's
it will bolt straight up but the diff is shorter and wont allow wide rims/tyres to fit on the back but if you have 14 or 15" rims this wont be an issue
im not admiring your car im looking in disgust
Thats interesting... because they used the VL turbo diff in the VN Group A and SV5000 BECAUSE they had larger wheel on the backOriginally Posted by HDT_aero
They used the diff because it was shorter and so there was no issues with scrubbing the guards.
They are 20mm shorter on each side, making a total of 40mm shorter.
They all fit. VL Turbo diff and VL V8 diff were the same, 4 pinion 28 spline diff. Just the VL turbs diff had the 3.45 gears while the V8 diff had the 3.08 gears.Originally Posted by boona15
But the N/A VL diff will also fit but you wouldnt wanna use it. Its a 2 pinion 25 spline diff...
But all the VL diffs are Borg Warner M78 Diffs just like the series 2 VK. And just like the VN-VS commodores as well.
All beam axle diffs from VB right through to VS have the same mounting points by the way.
yeah thanks im just puttin it in cause its shorter and my wheels wont scrub
You're not just putting a NA 6 cylinder VL diff in are you?Originally Posted by jeremy
I would definitely only use a VL V8 or VL Turbo diff. I wouldnt wanna use the 2 pinion 25 spline diff from a normal 6 cylinder VL in a VN/VP
i was just gonna use the vl housing and cut my axels down. whats up with the vl centers?
Just grab a VL V8 diff man. Not too expensive its just a matter of finding one.
You have 28 spline axles, which wont match up with the VL NA 6 diff...
Why would you only want the VL housing? What good is that? If it is the 3.45 ratio you want then simply take the gears.
there shorter by a inch or so my wheels wont scrub
will 4.11 s out off a pintara fit straight in to a vn diff
The diff gears will go straight in yes.
The actual diff will not and the centre will not as the Pintara's are a 25 spline, and your axles are 28 spline. Correct me if I am wrong on this...
