Results 1 to 9 of 9
Thread: clunking noise from the rear of the car
    Jun 2005
    Default clunking noise from the rear of the car
    just noticed something different with my car lately.
    if i am travelling, say, above 50 and i let it idle at that speed for a while for a while, when i press the accelerator i get a bit of a clunking noise from the rear. its makes one noise and then its fine. sounds like its from the diff.
    is this normal, or could something be wrong?
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
    Morton's Avatar
    Fairstar the Funship
    May 2006
    My old diff did that, when it had a busted centre bearing, cracked panhard bar rubbers, cracked upper and lower control arm bushes and rooted diff bushes. After I replaced them all and fitted a vs diff and lower arms, the clunking was fixed. I suspect it was the centre bearing that caused the clunk, but it could be a sign the diff is on the way out. If you get lucky, you can score a new one fairly cheaply. I got my vs diff fitted for $150 with the lower control arms.
    The 1972 HQ Kingswood
    pandaman's Avatar
    pandaman is offline Aussie Muscle Fan
    VN Berlina 5.0 A4
    Feb 2006
    Sounds like backlash, it happens when your driveline starts getting old and you start getting play between components. Or it could just be rooted bushes, easiest thing to check would be to look at the rear suspension bushes make sure they're intact, if so then theres probably some backlash in the diff.
    Beau Duke: Man, I'm never gonna get outta this car again. I'm gonna live in it, I'm gonna eat in it and I'm gonna make sweet love to it!
    Luke Duke: You mean you're gonna make sweet love IN it.
    Beau Duke: Oh no, I'm gonna have sex with it.
    savage1987's Avatar
    savage1987 is offline fail champion
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Cheers guys. I was having the same trouble, just wasn't too sure how to explain it lol. What diff options do I have? I'm looking for LSD . . . any bolt-overs from other models? Is there much modification of rear suspension required?
    And I don't really want to change the ratios too much, if I can help it . . . heaps of highway driving . . .
    Sammy B
    VT Berlina & mazda 2 DE
    Jul 2006
    i'm having similar noises, however i also seem to have a bit of 'wobble' in the ass end when coming to a full stop. Anything harder than a gentle stop and you can feel the back bouncing before coming to a stop.
    yes shocks are new...
    pandaman's Avatar
    VN Berlina 5.0 A4
    Feb 2006
    Quote Originally Posted by savage1987
    Sammy B
    An LSD diff from any VN sedan or live axle VP sedan will definitely fit. Other than that, Diff centres from VN/VP wagons and utes will also fit, but not too sure about the whole unit, theres probably a thread on it around here somewhere. Just do a search for LSD in the VN section, should turn something up.
    May 1991 VN Wagon V6 Auto
    Jan 2006
    Quote Originally Posted by bradcad
    You've got some worn bushes in your rear suspension. Possibly panhard rod bushes.
    Noise elimination I call it. Find noise, eliminate it. That's all I ever seem to be doing.
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    clunk when accelerating after coasting could be a badly worn universal in drive shaft, easily diagnosed by jacking up the car and manipulating the driveshaft by hand. any visible movement means it's shagged. otherwise bushes or to much play in the old diff. if your gonna get an LSD fitted, they should be able to sort that when they fit the LSD center and re-shim to set the crown to pinion back lash.
    Benji's Avatar
    Benji is offline Vote For Pedro
    Looking For A VR - VS Stato V8
    Aug 2005
    Central Coast
    yeah uni joint or centre bearing is what id be putting my money on
    My car does the same thing and its the centre bearing
    Cheers Benji
    [SIGPIC][/SIGPIC]
  1. Clunking noise from steering
    By porkkhunt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-10-2006, 07:01 AM
  2. clunking noise from under the dash
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 18-06-2006, 08:10 AM
  3. vt clubsport clunking noise
    By gazzabrizz in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-05-2006, 03:11 PM
  4. Clunking Noise
    By blade_1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-04-2005, 12:57 AM
  5. Clunking noise in reverse
    By ryan_VL in forum VL Holden Commodore (1986 - 1988)
    Last Post: 23-02-2005, 12:41 PM
