Results 1 to 4 of 4
Thread: Buying a vn
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    Default Buying a vn
    thinking about buying a vn if it comes up cheap just want to know what to look for thats wrong in it like normal places for rust also how to tell series 1 and 2 apart. some pretty comman faults to look for. I know its maroon a v6 and auto. The guy is buying a vx and was going to take the vn to the wreckers so i might get it real cheap depends how nice hes going to be.
    VZ LS1 Calais
    Dec 2005
    South Brisbane
    hmm, stuff to look for...ok, check around the power steering pump and reservoir for signs of leaking, also listen to steering when you take it for a drive...if possible get it up on a hoist or some ramps and look underneath (everything is revealed when your under a car) check for signs of dryed oil on the engine or perished suspension bushes, as well as signs that its been in a bad crash...
    check out the boot and rear windscreen/rear pillers thouroughly for rust, this is where it will be if there is any, it will most likely also have a boot leak (as most do) so the carpet in the boot will probably stink and the underlay will probably be falling apart...
    an easy way to tell series 1 or ll is to check if it has a radiator cap, if it doesnt its a series 1. (plenty of other ways, but thats pretty straight forward)
    being an auto take if for a drive, feel/listen for laboured or noisey gear shifts and get it up to 80k/hr...feel the converter lock up and then back off, if its shuddering and/or you can hear a loud vibration the converter is stuffed.
    other than that just check to see everything works (electricals,dash.etc..) and see how it drives..good luck.
    Pub247's Avatar
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    thanks for that thats pretty much what i wanted to know i'm pretty good with motors as i build them but ive only ever driven one vn years ago and none of my mates ever owned one but they not a bad car from what i hear and it'll be better than my vh but i'll miss the manual
    PaRaDoX's Avatar
    PaRaDoX is offline boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    ok
    check for oil leaks (main rear is the one u gotta look for)
    master brake cyclinder leaking
    rust under the boot carpet in the H frame for the tow bar if it has it
    check for cracked paint in the enginebay, if it has cracked paint then chances are its been in a smash like mine, also if u can jack it up and remove the front inner guards and check that paint
    listen for idle noises, check radiator overflow for oil/rust in fluid
    check for rust around front window
    most of all feel how she drives the buick engines dont usualy fail before the rest of the car, its everything else that brakes, trust me on that one
    check for smoke out the exhust
    put a peice of paper over the exhust, if its sucking in then blowing out its got rooted valves or they're not opening properly
    check to see if the starter works fine, i had a old one in mine that gutted half my ring gear,
    push on each corner of the car if it bounces then the suspension is worn, if it springs back to place shes all good
    listen for unusal idle noises
    pretty much sir cruize alot outlined it all
    over all feel how she drives, they'res a abundance of parts for em so fixin them aint hard or expensive
    good luck mate
  1. Buying a SV6
    By cladiges in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 25-03-2007, 04:53 AM
  2. When buying a vz
    By knight97 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 30-01-2007, 05:13 PM
  3. What to look out for when buying a vr
    By VKStevo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-10-2006, 11:19 PM
  4. Buying a VT SS 5.7
    By patullose in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-08-2006, 10:37 PM
  5. maybe buying a vs on gas - what to look for
    By vh-holden in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-11-2005, 06:11 PM
