Results 1 to 9 of 9
Thread: Problem with temp gage
    Phoenix21's Avatar
    Phoenix21 is offline Donating Member
    93 VR, 97 VT, 95 Statesman
    Feb 2006
    Crime bourne, Vic :P
    Default Problem with temp gage
    ok the other week i installed a new thermostat now ever since my temp gage hasn't been working it don't even move off the botom any advice would be great thanks matt
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    Phoenix21's Avatar
    Feb 2006
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    I found that with temp guages on vn's they take a while to indicate temp readings and they usually are quite low. So i give my car like 10 mins driving or warming up then knock it for 6 on the dash. But if you've tried that and you've just fiddled with the therostat then there is a high posibility thats there your problem lies.
    Phoenix21's Avatar
    Feb 2006
    yer i might have to ave a go at it again tomorrow when i did it i was able to get the throttle body off but the inlet manifold wouldn't come off so it was hell trying to get it off i'll try a few things in the next few days
    HATER VP Guest
    A sensor wont read anything if there is no coolant to read on. Did you put more coolant in and bleed the system?
    Phoenix21's Avatar
    Feb 2006
    bleed????? yer at the moment there is only water in there till i fix the heater lines but it should still work i think
    '08 Accord Euro
    Feb 2006
    yeah you need to bleed it. also could be the thermostat is stuffed - ie stuck open - ive had this several times with new thermostats, bloody annoying - especially on the series 1's, where they are a slut to get too....
    Phoenix21's Avatar
    Feb 2006
    man i hope its not screwed is it fixable if its stuck open and um lol im ganna sound like a total noob but anyways i dunno what bleed it is (is it just running it with the cap off or somthing) thanks matt
  1. temp problem
    By Mr_Calais in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 19-01-2007, 02:15 AM
  2. Vx coolant temp to high? sender problem?
    By rgormley in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-01-2006, 03:49 AM
  3. wtb roll gage
    By hinterland in forum Swap / Wanted to Buy / Trade
    Last Post: 06-11-2005, 09:27 AM
  4. Problem with fuel and temp gauges
    By rot10n in forum Electrical Wiring / Questions
    Last Post: 15-08-2005, 07:30 PM
  5. small temp problem
    By gus_tinkle in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-06-2005, 11:53 PM
