Results 1 to 11 of 11
Thread: tapping noise in engine
    SUPERCHARGED VP COMMODORE
    Feb 2005
    Ipswich
    Default tapping noise in engine
    ok only started this morning
    started the car and i usually let the car sit for a few minutes before driving and i noticed a slight tapping noise ( i dont know anything about engines ) but sounded like the lifter at the rear was tapping and not getting any oil. With a bit of acceleration the tapping noise was faster and louder. I had to go to work and under idle couldn't hear anything but driving was pretty noisy. After a few minutes it did go away . I only work five minutes MAX away and by the time i got there it was gone.
    Now before any comments on oil
    It is regularly serviced ( only 4500km ago ) Six months
    There is oil! And good quality clean oil!
    It just sounds like the one isnt pumping any oil but after a few minutes the others lubricate this one up ??????????????????????????????????????????
    There is no power loss ( that i can notice but i have driven it very carefully obviousley)
    Any ideas what it is so i have an idea when i go to get it looked at on Monday
    Any help Thanks
    [SIGPIC][/SIGPIC]1993 Supercharged VP
    Feb 2005
    Ipswich
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    Feb 2005
    Ipswich
    no
    there is the usual tap from the injectors but this is definatley in the engine
    thanks anyway.
    anyone had similar prob. with only one rocker being noisy
    seal? not getting any oil???
    i dont know
    As i said there is no power loss and no smoke whatsoever coming out the back.
    After 5 minutes ok sounds like normal but just the one
    VY S2 Berlina
    Jul 2005
    Wide Bay, Queensland
    take rocker cover off and tighten all the rocker arm bolts, hope helps, if not try using Lifter Free its about 10 bux a bottle
    Current: My Ride
    VY Series 2 Berlina, Leather
    Previous: Ride 2
    VR Executive, 5 Speed Manual, Ecotec 3.8
    prince_dj666's Avatar
    prince_dj666 is offline hypo v6
    http://www.cardomain.com/ride/2112842/1
    Oct 2005
    QLD
    my car now does that.... did oil change and it started making tapping sounds. so i did another oil change with diff brand of oil and lifter juice and it still does it.. starting to get worse now. also fuel economy has dropped.. from 450-470 a tank to 330-350 a tank.
    VS Commodore Acclaim
    Jan 2006
    If it is a single hydraulic tappet bleeding down, then it will not make a noise every time the engine is left for a while as the engine stops in any one of 3 places on a 6 cylinder. It bleeds down when the valve has to be held open against valve spring pressure and then takes a while to fill with oil as they have a small hole to let the oil in. If an engine is sludged or poor quality oil is used this is more likely to happen. The lifters can wear depending on the quality of heat treatment of the wearing parts over which you have no control. You can try a Nulon additive for lifters and if it works OK otherwise they can be pulled apart individually unless you follow a regime of keeping all lifter parts in discreet containers. The valve can sometimes be turned upside down and lapped with jewllers rouge or the like if you are that desparate but simply replacing the faulty one is the best. Also look at the rocker incase this has wear. The hardest job will be locating the offender - thank your lucky stars you dont have a 24 valve engine. Holden have a time for the lifters to stop making a noise but is designed to avoid warranty claims something like 3 minutes per start.
    Feb 2005
    Ipswich
    yea i know where the offender is. He is the only noisy bastard there. So hopefully will just be the one loose rocker
    will have a look tomorrow .
    Thanks for all comments and let you know.
    VX SS 5.7L M6
    Jul 2005
    W.A. Perth
    sounds like a noisy tappet normaly caused by not enough oil. its not really serious. try an oil filter and oil change see if that fixes it.
    13.3 1/4 exhaust only untuned!
    MavVP Guest
    I have a similar tapping noise but i have a small hole in my manifold that is causing it, might look there as well
    Feb 2005
    Ipswich
    Default Problem Solved!
    MavVP you are almost spot on
    I had new extractors put on 8 months ago
    Upon much closer inspection ( first day off and proper look )
    The last two bolts were coming loose.
    A quick tighten and check of the rest and we are away.
    It seems when they got hot they expanded to tighten up and thats why it went away. Thanks all for comments and although problem solved before mavVP responded YOU WERE RIGHT THANKS
  1. tapping noise inengine
    By willy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-08-2006, 12:08 PM
  2. Tapping noise coming from back end
    By ::Team420:: in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-08-2006, 11:59 AM
  3. Tapping Noise
    By Bloka in forum General
    Last Post: 24-07-2006, 01:31 PM
  4. engine tapping when cold
    By TINYTIM in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-04-2006, 12:19 PM
  5. Loud Tapping Noise
    By nelly77au in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-08-2005, 01:44 PM
