Results 1 to 16 of 16
Thread: VN power steering leak
    VN calais 91
    Aug 2005
    Default VN power steering leak
    hey all
    i know my problems common and has been covered before, but there wasn't a direct answer for it
    leaking power steering fliud, it's dripping onto the oil filter
    got under and had a look, the entire lower section housing of the pump is just smeared in grease n black gunk
    think it's fubar? or could it just be a small leak that needs to be tigthened?
    lookin at the gregories book, could it be mabe a spring or plate or o ring gone?
    or does anyone know anyone selling a powersteetring pump?
    VN series II custom :) and VZ exec
    May 2005
    Mildura
    take it in to get rebuilt, or have a go yourself, they not to bad, i just put a kit through one at work just the other day, and its not as hard as i thought, but yeah pretty sure its normally an o'ring that has gone inside it,
    VT Berlina & mazda 2 DE
    Jul 2006
    dont know where you are but a mate (ex fulcrum and BHSS) rebuilds racks & pumps for cash. Fairly simple job though. Check your pump isn't fubar and it hasnt pushed shit through your rack, or that will need rebuilding too. Most of my cars- the pump goes, the rack isnt far behind.
    89 VN Commodore Wagon
    Jul 2006
    Well i live on the central coast & my power steering pump died & i,m getting a full rebuilt one in exchange for my one for $120 is that a good price or are they cheaper
    Shortstuff's Avatar
    Shortstuff is offline Random
    1995 VR II V6 Wagon
    May 2006
    Loads of pumps on eBay too, second hand and recon. About $100 for a recon one.
    Recon pump
    Used pump
    Personally i'd go for the recon since you could have the same problem again sooner than you'd want using a second hand one!
    Whoever said 'There is no substitute for cubes' had obviously never heard of Jet power
    VN calais 91
    Aug 2005
    so u rekcon this is all i'll need?
    i'm thinking of the recon one
    is it a big job removing the pulley wheel from infront?
    is there anyway to check wha'ts wrong before removing and stripping it?
    ie. by checking/looking?
    p.s i'm from SE melbourne, around dandenong
    anyone able to help me out?
    May 2005
    Mildura
    well to get the pulley of just undo the bolts on the front 10mm i think, i normally do it with the belt still on so i can stop it from moving, sometimes it works sometimes i use a screwdriver between the bolt and centre of the pulley bit hard to explain, once you crack the bolts loose then remove te belt and then remove all the bolts and pul the pulley off
    savage1987's Avatar
    savage1987 is offline fail champion
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Quote Originally Posted by timmy_tam
    Certainly not. It is actually very easy. I did the reconditioned pump swap very recently (last 2 weeks).
    Crack the bolts with the belt still on, so the pulley doesn't spin. Don't take them all the way out, just loosen them. Then take off the drive belt and remove bolts altogether. The pulley should just lift off - mine wasn't stuck at all . . . You might want to give it a clean when you get it off - mine was disgusting! Pump is easy to replace, that said I had a Gregory's manual to follow.
    Another thing that'll tell you your pump is on its way out is fluid trace on the bonnet. Wipe the underside of your bonnet clean, go for a drive and check your bonnet afterwards.
    With my VN, I had serious problems with fluid loss, it was squirting onto the bonnet, and dripping on the oil filter, and getting on the drive belt - causing a permanent squeak at low RPM that nearly drove me insane . . .
    I replaced the pump - got a completely reconditioned one (on exchange with Holden Parts department) with 2 fresh O-rings (for fluid tank and the high-pressure hose, from memory . . .) for about $165. This fixed all my problems
    Hope that helps
    Sam
    VN calais 91
    Aug 2005
    thanks for all the help guys!!
    so from what everyone says, it should be a piece of p!$$ to do
    i've been quoted $90 bux for exchange and recon
    or maybe it was $90 bux to fix my current one
    so i think tha'ts a pretty good deal
    and yeh, it does splash everywhere, its on the underside of the bonnet dribbling all over the place
    i even tried the 'stop pump leak' fluid
    let me tell you that's a big waste of money!
    thanks again guys
    tam
    prince_dj666's Avatar
    prince_dj666 is offline hypo v6
    http://www.cardomain.com/ride/2112842/1
    Oct 2005
    QLD
    hey all
    that has happen to my vn too. it leaks. but i just kept refilling it. anyway after time the fluid eats away the wires near, just under pump. and has sparked a few times.... making short circuts sounds.... then one day it lite up. lucky i have a extinguser handy from my previous nos set up. it saved me $$$$$.
    VN calais 91
    Aug 2005
    are you sersious mate? it started a fire because of the leak?!?!?!?!?
    FCUK!!!!
    better get it fixed then
    already, i can tell it's stuffed up the wiring underneath, it keeps blinking to 'fill up oil' even when it's filled, so gotta be an issue
    thanks again!
    cheers
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    hmm I wasn't aware of this either . . . maybe I should check out my wiring . . .
    Thanks for the pointer, prince_dj666
    VN
    Sep 2006
    I had a leak for awhile went exchanged the pump and all then realized it was the filler tank leaking at bottom ... it sits on an o ring... well tried new o ring still leaked... then though **** it .. i just smeared the new o ring with some black silicone and put it together while silicone wet (filler tank back on ) and waited a few hours to let it all dry and bingo hasn't leaked since .. also look at the main high pressure hose to the rack this is a real problem ... .they tend to leak, so always buy a new one ... as it not that dear and saves ya redoing it !!!
    VS Commodore Acclaim
    Jan 2006
    Quote Originally Posted by prince_dj666
    Be aware that autotransmission fluid has a low flash point so it is easy to set it on fire. Some years ago Ford had a problem with the Falcon where the auto dipstick tube was directly under the drip point of the bonnet when it was opened. This meant water ran down into the transmission if the bonnet was opened in the rain or after a car wash. When the car was driven the operating temperature of the oil was above the boiling point of the water. The water is heavier than the oil so the oil was blown out of the dip stick onto the hot exhaust manifold causing a fire. There was a recall for this.
    Any time power steering oil can spray/drip onto the exhaust it should be considered as a potential danger.
  15. #15
    vn89calais
    Oct 2008
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Quote Originally Posted by Don Sutton View Post
    LOL @ Ford!!
    WTB: mulberry VN interior parts
  1. Power Steering Pump Leak
    By Lord-Data in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-02-2012, 02:59 PM
  2. power steering leak
    By stocky in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-12-2006, 09:59 PM
  3. VN power steering fluid leak
    By savage1987 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-05-2006, 11:23 PM
  4. Power steering leak?
    By Sons1vn2nv in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-10-2005, 11:03 PM
  5. VS power steering leak
    By Dustin in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-08-2005, 04:35 PM
