can someone help me with a diagram or pictures of a vn series 2 cruise control fitted please![]()
Do you mean a wiring diagram?? Theyre fairly simple. You have to get the brake (and clutch switchs if its a manual) and the buttons up on the top right of the instrument cluster. These are wired to the control module which is mounted on the inside of the passenger side front guard. A cable then goes from the control module to the Throttle Body. I attached a wiring diagram for you.
thanx for that i allready have the plugs behind the instrument panel but cant find where they are going because it is a series 2 berlina the plugs are allready there.Do you have any ideas?
They will already be running to the plug under the bonnet for the stepper motor like in the diagram which you will find taped back to the loom near the airbox if you have the wiring already installed under the dash.
This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain
......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
thanx for that will have a look.Will let you know.
i cant find the wiring under the bonnet but the wiring for the brakes and the switch are both there anyone got any sugges?![]()
The wiring on mine, following back from the module, goes under the airbox, and over across the top of the radiator, then up the drivers side of the car and into a gromot hole, although I think my cruise control was fitted after the factory buts its definately genuine holden cruise control.Originally Posted by grum1971
Hope that help you.
so.. do all series 2 vn's have the wiring or not..
hi i am doing this conversion and following your diagram. can you tell me if i can wire this up through my original brake light switch as i was not supplied any specific to the cruise when i bought it? Thanks Jamie
Love a good thread dig!
BTW, you don't have to run a switch on the clutch. Its common sense not to change gears with the cruise on. Although it is still possible!
Originally Posted by davway
I can change gears with the cruise activated without even rising more than 2000rpm before i let the clutch out!
As i said, the clutch switch isn't need unless your grandma is borrowing the car.
thanks greatly . Jamie
i just finished wiring up my cruise control i got out of a vn calais into my exec. though it does not worklight in switch block works, got everything wired up correctly though do not have brake switches, so in the pic, i just joined the brown wire to the green/grey wire. or does the it work a different way? (open circuit to work?)
also with the speed sensor wire, it says to go to plug 3 pin 5, which on mine is the pulses. does it go there or to the speed signal which on mine is plug 2 pin 7 which is how it is now.
