Results 1 to 9 of 9
Thread: jolt from 1st to 2nd???
    vn berlina
    Jul 2006
    Default jolt from 1st to 2nd???
    when my auto changes from 1st to 2nd, u can feel the gear change, then there is a small delay and a big jolt - pretty uncomfortable. it gets worse the warmer the car is and the harder you drive it. only does it from 1st 2nd - no other gears. my mechanic said it was the lower control arms, so i got those replaced. it improved a bit, but got back to crap pretty soon. then went to transmission place and they said they could give it a service and put a notch in the belt.
    problem has returned again and is as bad ever.
    got no idea what the prob is????????
    anybody help?????
    savage1987's Avatar
    savage1987 is offline fail champion
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Get your auto transmission serviced - or at least take it to a specialist and ask them to have a drive and tell you what they think . . .
    Mine had a similar problem - auto service fixed it no worries for just over $100
    'they said they could give it a service and put a notch in the belt' - I don't know what that means but it doesn't sound right . . . you should always fix the problem, not its symptoms . . . All I can say is try taking it to ANOTHER transmission joint and let them have a drive . . .
    Hope this helps . . .
    jules's Avatar
    jules is offline we like the bun
    pimpin
    Dec 2003
    the accumulators in the trans hydraulics have the job of cushioning the change by modulating pressure. when they start to go i believe they can make the shift rough, particularly the 1-2 shift on light throttle.
    whoever told you to change the control arms, don't ever go back to them! there are also no belts in the transmission.
    vn berlina
    Jul 2006
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    90 VN SS 5speed, '90 VN Calais 5speed
    Jan 2006
    stanthorpe, qld
    Quote Originally Posted by Mack
    Adjust the kickdown cable...
    ur right its the kickdown cable mine use to be like that and i adjusted it and it changes PERFECT.
    hard shift from 1st to 2nd
    Adam
    2001 VX calais (sprgd) ser II
    Nov 2008
    Default tranny
    try getting it plugged in at a transmission place, sounds like shift solenoids are on the way out
    Cobez's Avatar
    Cobez is offline LS-EXUAL
    2004 S2 VY SS Ute
    Feb 2007
    LOL, wtf? Do you realise this thread is 3 years old? lol he probably doesn't even own that car anymore lol.
    Quote Originally Posted by wikky
    As already stated, mate you're an absolute gherkin strummer.
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    haha I wondered why I couldn't remember posting in this thread
    WTB: mulberry VN interior parts
  1. 02 VXII Stutter/Jolt Problem
    By vagure5 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-12-2006, 12:25 PM
