Will a VN VP or a VR manual gearbox fit a VS series one commmodore as a manual conversion and if so will it take much modifiying? thanks for your help in advance people
The box is the same (T5) but if you have a series 1 VN, then the flywheel will be 6 bolt instead of 8 bolt.
Also the VS Ecotec has a whole lot more power behind it than Buick, so you may need a different clutch...
