Results 1 to 10 of 10
Thread: 4.11 diff in vn
    driftking Guest
    Arrow 4.11 diff in vn
    does a 4.11 out of a pintara go straight in to a vn if not wat do i need i have changed centres be fore but not sure if axels will fit and all the other bull shit
    1991_Vn2nV's Avatar
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    The diff gears will go straight in yes.
    The actual diff will not and the centre will not as the Pintara's are a 25 spline, and your axles are 28 spline. Correct me if I am wrong on this...
    driftking Guest
    so if i got pintara axels and weld the holden stud pattern on the end of the axel to the same length of the vn axel will that work as i am a boiler maker so i can do that at work
    HATER VP Guest
    1991_Vn2nV's Avatar
    Mar 2006
    Quote Originally Posted by driftking
    No..dont do it. The pintara axles are weaker than the VN ones, why wouldnt you want to keep the VN axles?
    All you want is the gear ratio of 4.11... Thats it. Just take the gears out of the Pintara diff and put them into yours. Simple. The VN diff is better than the Pintara one in every other aspect, so why would you want any other part of it?
    VS SS 5.0ltr
    May 2006
    queensland
    i got a 4:11 in my vp but i dunno how they fitted it but think the brakets little different but that was when i looked at my friends vn
    driftking Guest
    vt1538's Avatar
    vt1538 is offline 455rwhp LS3
    VY SS S2 11.284@125mph
    Sep 2005
    The Dead Centre
    Its a bit of work.
    You will need to replace the crown wheel & pinion off your old diff centre with the 4.11 set off the pintara. The internal gears are the ones with the different splines so the commodore axles will be re used. The main problem you will have is to get the tooth contact & preload of the bearings right. If you are lucky you will get it right first time but I doubt it.
    If you end up with too much clearance in the gears a noisy diff will result & possible failure or premature wear.
    Too tight & it will also fail.
    The only advice I could give is to read a manual & ensure you understand it fully before attempting.
    driftking Guest
    so what kind of manual do you recomend to read and is there a different ratio than standard that will bolt straight in to the vn diff
    vt1538's Avatar
    Sep 2005
    The Dead Centre
    Any manual with the Borg Warner diff will do. The main bit you will need to know is the tooth contact & how to adjust it.
    To get the contact & preload may take a few times of assembling & disassembling so you want to make sure you are going the right way. It would also help if you know a mechanics shop or diff joint that will lend you there selection of spacers while assembling, as this is how the carrier is moved in relation to the pinion.
  1. V8 Diff vs 6cyl Diff
    By RSO in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-04-2009, 09:45 PM
  2. diff making a noise / replacing diff
    By yipya in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-12-2008, 11:30 PM
  3. Putting in new diff oil and replacing diff gasket ?
    By gemini in forum VL Holden Commodore (1986 - 1988)
    Last Post: 07-10-2007, 05:22 PM
  4. VL Diff
    By Hooligan in forum VL Holden Commodore (1986 - 1988)
    Last Post: 02-05-2007, 09:04 PM
  5. EL XR6 diff on VS?
    By sircruisealotVS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-02-2007, 05:39 PM
