Results 1 to 11 of 11
Thread: Pod Filter-easy as
    VP executive V6
    Aug 2006
    Pinjarra (Perth) WA
    Default Pod Filter-easy as
    Had pods on all my cars-so easy to put on a V6!!
    Simply take out the standard box (this leaves room for air horns) and last short bit of length from main black pipe.
    Put on pod and tighten.
    Bend the length of holed soft steel strap that comes with pod so one end slips in the front lip of pod.
    bend to shape and fasten ontp left upper bolt from where standard air filter box was. Finished!!!
    Had it on for 12 months and no probs.
    jolly_97's Avatar
    jolly_97 is offline THE VACATIONER!
    1992 VP Vacationer
    Mar 2006
    Port Lincoln
    ok cheers for that, but shouldnt it be in the how-to section
    Quote Originally Posted by Stevob
    I check my oil every 3 minutes...just to be sure.
    HEY RICE BOY! I GOT TORQUE, U GOT TALK!
    my ride- http://forums.justcommodores.com.au/...ad.php?t=29425 newest pics last page...
    THE VACATIONER LIVES
    jolly_97's Avatar
    1992 VP Vacationer
    Mar 2006
    Port Lincoln
    double post but meh, this has gone cold anyway.
    u noticed much with ure pod filter on? coz im debating wether to get a CAI or Pod, this is one of those arguments that could go on forever - just like ford vs holden...
    xcop5l's Avatar
    xcop5l is offline 4th year spanner spinner
    VN ex cop 5L
    Jun 2006
    ol' geelong vic
    cai is better than pod becaue you dont want exsevive heat reentering the engine
    Stato on the inside, berlina on the out side,5ltr under the bonnet,stockies all round...........that thing has to be a sleeper
    MY RIDES
    [SIGPIC][/SIGPIC]
    http://forums.justcommodores.com.au/...ad.php?t=41837
    SMIT's Avatar
    SMIT is offline Donating Member
    VT C2R TURBO 5SP + CRUNCH VE SSV 6SP
    Aug 2005
    Mornington Peninsula, Victoria
    jolly_97's Avatar
    1992 VP Vacationer
    Mar 2006
    Port Lincoln
    yeah, i think ill go with CAI and maybe modify the setup like kinkbikes later...
    HATER VP Guest
    Dont worry about the warm air intake. Get a CAI with K&N Filter.
    Dont bother with CAI into a pod.
    VN calais 91
    Aug 2005
    Morton's Avatar
    Fairstar the Funship
    May 2006
    It's hard to notice the difference in response with the pod in a v6, because you've got so much power already, the increase in throttle response is negligible. But when I whacked the pod on my old 4cyl 626, I noticed an -instant- jump in throttle pickup, and an easier rev up past 4000. Even my mate noticed it from the passenger seat. The difference was especially noticible with a 2" exhaust on.
    On the commodore, I noticed very little difference, if any, when I put the pod on. If I ever get a performance exhaust I'll try the pod again, though. That's probably the only time it's really worth risking the EPA infringement.
    The 1972 HQ Kingswood
    VS SS 5.0ltr
    May 2006
    queensland
    shouldnt fit pod filters because it sucks hot air from inside the engine bay and can uppset your ecu better off getting the cold air intake for 80 and get a kn filter
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    Well, from past experiences on my 91 VN:
    Pod (No CAI): Louder induction sound, little beter response.
    Pod (with CAI): Just as loud, cant feel much of a difference from with no cai.
    CAI (non high flow pannel filter): Little less noisy then Pod, but not that great.
    Over all I think ppl spend too much time on these setups, just pick one and if it dosent work for you, then change it. Ive tryed a few setups and ive stayed with the CAI into pannel filter just for a more complete look under the bonnet(and to stay on the right side of the law). If a pod made a worthy difference then I would have it on all the time. I also recently installed a air scoop device that sits behind the grill to direct air flow up and into the CAI. To tell you the truth, even that cant make a distinct change.
  1. EASY WAY 2 do fuel filter quickkkkkkkkkk!!!!!!!!!!!!!!!!!
    By Joey_21 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-09-2007, 09:50 AM
  2. I need help !!!! Easy $100 US
    By doyle4281 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 02-11-2006, 01:42 PM
  3. 3.8 into VK easy swap?
    By VRSS in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 18-06-2006, 09:21 PM
  4. An easy question
    By Mr_Slim in forum Car Audio
    Last Post: 07-06-2006, 08:01 PM
  5. An easy fix?
    By SL/ENUT in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 21-02-2005, 03:41 PM
