Results 1 to 13 of 13
Thread: Locked myself in my car?
    Jul 2005
    Default Locked myself in my car?
    Hey I drive a VP Berlina (wagon if it makes any difference). Today i got back to my car to find the key wouldnt turn in the drivers door...As when the door is locked manually the immobiliser control cant unlock the doors, the only way I could get into my car was to open the tail gate and climb in. Once boot is closed I find myself locked in, as the door switches are all locked down, the only way out is through my windows... so when I have to leave my car I have to climb out and climb back in through the back to wind down the windows..I assume that the problem isnt with my key(s) because both my car keys can turn the car on...I'm guessing you will advise me to get my lock changed which will cost heaps, so I was wondering is there some sort of trick I can use to unlock this door once, so that in future I can use my immobiliser to lock/unlock my car in the future??
    Please help as you can imagine, I'm pretty over this.
    VR SS manual
    Apr 2006
    yeah u have activated the deadlock try turning your key the other way round if that makes sence and jiggle it in the lock may work
    missus (in more ways than one)
    Sep 2005
    pull the power off the battery and manually pull it up, if not rip off door trim and pull it up from there, i dont realy understand thou
    Doctor Sodways's Avatar
    Doctor Sodways is offline Legendary Baby!
    Slammed VeeDub Rat and a Brunette...
    Sep 2005
    Behind a Camera...
    I think you have deadlocked the doors, as vpbt1ss said. Although, the first thing i thought off when i read the title, was that episode of family guy when peter locks himself in his car, lol, that was funny
    GOOD LUCK!!!
    I used to play sports. Then I realized you can buy trophies. Now I’m good at everything.
    The best car safety device is a rear-view mirror with a cop in it. ~ Dudley Moore.
    VS Exec 6 seater
    Jul 2005
    Hey.. My Mrs did this the other day, check ur lock on the drivers door, if the slot is horozontal, you have activated the deadlock. As this is a feature not used very much by many drivers, when they accidentally turn it to this position it is very difficult to turn back. Use a bit of brute force to turn it CLOCKWISE (or you will break the key) until it is vertical again as it tends to be a bit stiff if not used very often. The commodore keys are quite thick, so you shouldn't have to worry about key breakage while doing this.
    Shortstuff's Avatar
    Shortstuff is offline Random
    1995 VR II V6 Wagon
    May 2006
    I'm going by what i've seen on Vauxhalls, but the symptoms sound identical so here it is. I think this may be your problem.
    On the inside of the door handle (around the lock barrell) there is a fairly small metal ring that turns when you put the key in and turn it. It then operates the lock and deadlock. I think this ring is made of crappy cast iron and breaks easily if it gets stuck, which is what I think has happened to yours.
    The easiest way to fix it is to get a whole handle from the wreckers and just change the lock barrell out of your car into th new handle. It's a real fiddly job to change just the broken ring as there is a tiny bearing which pops out and gets lost!!
    To get the door open you can try gently wiggling the key in the lock and see if it helps, but you will probably have to get the door trim off and release the lock from inside the door which can be difficult. Unfortunately there isn't a quick fix if this is the problem. If the broken part doesn't get replaced then you may have problems even locking the car without the deadlocks.
    Hope this makes sense and helps. If you wanted to get the part from Holden, I think it's called a Door Lock Rotator.
    Whoever said 'There is no substitute for cubes' had obviously never heard of Jet power
    1991_Vn2nV's Avatar
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    Similar thing happened to me this morning.
    The locks were only coming halfway up, so it looked unlocked sorta, but would not open. I used the alarm remote to activate the central locking, so it locked again, then unlocked and they would open... No idea what was goin on there?
    jolly_97's Avatar
    jolly_97 is offline THE VACATIONER!
    1992 VP Vacationer
    Mar 2006
    Port Lincoln
    yeah i only realised my car had deadlock on it the other day, press the button to lock it normally then lock it again with the key (cant remember which way to turn) and the slot will turn horizontal. then u gotta get the deadlock off with the key, then unlock it with the button if u have ure immobiliser function on...
    funny, guys that installed my cars stereo tripped the immobiliser, took them another whole day to figure out where they had screwed up lol
    Quote Originally Posted by Stevob
    I check my oil every 3 minutes...just to be sure.
    HEY RICE BOY! I GOT TORQUE, U GOT TALK!
    my ride- http://forums.justcommodores.com.au/...ad.php?t=29425 newest pics last page...
    THE VACATIONER LIVES
    fu2's Avatar
    fu2
    fu2 is offline The Man With No Name
    VP Berlina II - MY10 VE SV6 Ute - VH SL/E
    Jul 2004
    Quote Originally Posted by Doctor Sodways
    GOOD LUCK!!!
    lol i thought the same thing lol
    yeah its definently deadlock if you cant unlock the doors from the inside.
    if the slit for the lock is hoizontal then then turn it right untill it is vertical
    Jul 2005
    I cant turn the key it just wont give me anything, thats the prob. Oh well looks like I'll haev to get a new lock. Thanks for the help eveyrone, let me know if you have any other ideas
    Dezza's Avatar
    Dezza is offline your local HSV dealer
    Cammed up Vy Clubby
    Feb 2004
    did u check the fuses? this happend in my pajero i lock the car but then cant unlock it with the controler or the key but my rear door still unlocks its not on the central locking i keep blowing fuses i repolace and it works
    Shortstuff's Avatar
    1995 VR II V6 Wagon
    May 2006
    Cheapest and easiest way is just to get another complete handle from the wreckers and put your lock barrell into it. The barrell is only held in by a circlip I think. I don't think the problem is actually in the lock itself, but due to part of the mechanism which is attatched to the handle.
    Where abouts are you? If near Melbourne i'm more than willing to lend a hand and there's a VP in the wreckers across the road from me with the bits you may need.
    SweetWagon's Avatar
    SweetWagon is offline booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    This just made me think of this video I saw. funny as hell, click here to see!
  1. locked vp HELP!
    By yggdrasil in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-01-2008, 09:19 AM
  2. VY ecu locked?
    By truckin in forum VY Holden Commodore (2002 - 2004)
    Last Post: 19-10-2006, 03:24 PM
  3. Help. Locked out of my VX.
    By A57 HSV in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-12-2005, 11:13 PM
  4. Locked out of VT
    By VT Calais 5.0 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-08-2005, 09:10 PM
  5. locked up
    By oshe in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-05-2005, 11:26 PM
