Results 1 to 6 of 6
Thread: oil leak
    drans_vp Guest
    Default oil leak
    i think im leaking oil from my sump but have no idea how to drop my sump or what eva were do i begin and is it easy to repair
    drans_vp Guest
    HATER VP Guest
    VP S Model
    Apr 2005
    yeah ive got the same prob. Its pooling at the bottom of the sump and dripping. If the rear main seal was stuffed, would that cause the oil to pool at the bottom of the sump?
    How hard is it to replace the rear main on a 92' VP? Or how hard is it to remove the sump?
    94 vr 5sp, 04 vz wagon,82 vh efi wagon,88 vn 5sp
    Nov 2003
    northside brisbane
    Take gearbox off and flexplate or flywheel depending on gearbox.Taking old seal is easy...replacing seal is difficult as it has to be put in at a certain depth on the crankshaft boss seal surface.You dont just hit it until it bottoms you have to be careful and in the manual it shows a tool that you screw on to the crankshaft and wind the seal and it automatically stops at the right depth.I suppose if you are careful you could make a collar that would do the same job or use a depth gauge at various places to ensure the right installation.
    This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain ......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
    xcop5l's Avatar
    xcop5l is offline 4th year spanner spinner
    VN ex cop 5L
    Jun 2006
    ol' geelong vic
    also if the seal has worn a groove in the crank you will have to get it resleaved.
    Stato on the inside, berlina on the out side,5ltr under the bonnet,stockies all round...........that thing has to be a sleeper
    MY RIDES
    [SIGPIC][/SIGPIC]
    http://forums.justcommodores.com.au/...ad.php?t=41837
  1. Vn Oil Leak :(
    By VNPOWER in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-09-2008, 09:27 AM
  2. Vn Leak!!!! Help
    By spacattack in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-02-2007, 08:05 AM
  3. V bad oil leak!
    By hotrod32 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-04-2006, 02:08 PM
  4. Oil leak
    By newo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-01-2006, 09:14 PM
  5. Oil Leak
    By paullmichelle in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-10-2004, 10:15 PM
