Results 1 to 4 of 4
Thread: Having a skitz
    VNV6VENGEANCE's Avatar
    VNV6VENGEANCE is offline VeNgeance
    VN Turbo
    Jan 2006
    adelaide,sa
    Default Having a skitz
    Really not happy today .... went to switch over the engine mounts on my vn v6 today and found that the bolts all came off easilly, the car jacked up easy and lifted the engine from the mounts. there didn't seem to be enough room for the mounts to come out. Does the car need to be put on a hoist? how much is this job worth?
    only good cops a dead cop...
    s1 vn commodore turbo
    t3/t4 front mounted turbo
    Intercooler ---3"exhaust
    stage 2 shift kit---B&M Qicksilver shifter
    3:45 lsd
    18" Cv8z Monaro rims 245's
    xcop5l's Avatar
    xcop5l is offline 4th year spanner spinner
    VN ex cop 5L
    Jun 2006
    ol' geelong vic
    nope the easest way to do it is to undo the four bolsf for the k frame and drop it down. make suer u support the engine so it dont come down with hte k frame then you should be abil to slp them out
    Stato on the inside, berlina on the out side,5ltr under the bonnet,stockies all round...........that thing has to be a sleeper
    MY RIDES
    [SIGPIC][/SIGPIC]
    http://forums.justcommodores.com.au/...ad.php?t=41837
    89 VN Commodore Wagon
    Jul 2006
    Ok well if you hav,nt got a manual for it this is what it says in mine
    1)disconnect the negative battery terminal
    2)release the clamp securing the air inlet hose to the throttle body & disconnect the hose
    3)raise the front of the vehicle & support it on stands
    4)remove the nuts securing the engine mounting to the crossmember & the engine bracket
    5)using a suitable lifting tackle,raise the engine until the weight is taken off the engine mountings
    6)when removing the left hand engine mounting proceed as follows
    a)On automatic transmission models,remove the bolt securing the front of the starter motor to the engine bracket
    b)On aircondition models,remove the airconditioner compressor retaining bolts & secure the compressor away from the engine
    7)Remove the engine bracket retaining bolts raise the engine slightly & remove the engine bracket & engine mounting
    now hope that helps but will be doing mine soon so tell ya how it goes as i dont have a lifting hoist & that is how it says to do it from the manual
    VN Turbo
    Jan 2006
    adelaide,sa
    cheers boys i'm getting a b&m quicksilver shifter in today and the trans guys are going to fix it cheap while they do it. thanks for the walkthrough.
    3:45 lsd
