Results 1 to 9 of 9
Thread: Replacing Antenna on 1991 VN
    Feb 2005
    Default Replacing Antenna on 1991 VN
    Hello All,
    Our antenna broke after a tree branch collected it.
    Does anyone have instructions on replacing the antenna? - I have a purchased a new one (aerpro). Also, should I fit a noise filter to it? - our old one used to pick up engine noise at times.
    Many thanks in advance.
    VN Caladore
    Aug 2006
    Not sure how to fit it, but yeah put the noise filter on it..
    I want to replace my antenna cause it is not going up/down when you hit the button... You can hear the motor working, but the arial doesn't move ...
    I spend too much money on my cars & bike
    Click me to see my ride
    vn25det Guest
    u need to remove the inner plastic part of the guard. then from the its simple there is just 1 10mm head bolt that holds it in, undo it with a spanner, unclip the earth strap which is just a female spade, disconect the black areal cable (same connection as at head deck) then just slide the whole ariel down out of the gaurd. all done and just install in reverse. when i upgraded my manual to electric it took all of 10min to do. hardest part is undoing the screws that hold the inner guard on as they rust and strip out easy.
    Feb 2005
    Many thanks for your replies.
    Did you replace the cable right back to the radio?
    1991_Vn2nV's Avatar
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    All you need is a mast if its been hit by a branch, not an entire aerial.
    Mast = $30, Aerial = $90.
    Plus Aerpro aerials are not fully compatible with the VN module and 8 out of 10 times the aerial will go straight back down after it goes up. The Aerpro aerial is VN-VS or something? It suits a few different models anyway, but is not compatible with all the modules. The VN alone had 2 or 3 different modules in its production, in which I know the one in the Series 2 (1991) VN's is not compatible as I have found out with my own aerpro aerial.
    And imo a noise filter is not necessary at all...
    Feb 2005
    VN Calais
    Feb 2006
    GolD Coast
    1. Jack the car up on the left side, it will give you plenty of room to get that guard liner released
    2. undo the antenna mount bolt you will be able to see
    3. undo the earth strap which is a tiny phillips head screw near the antenna mount
    4. release the trims near the passengers foot on the left side, you should be able to see the coaxial connection, unplug it and pull the cable out from under the guard, there's a rubber grommet that the cable runs through but should pull out when you pull the cable from under the guard.
    all the best.
    wes_v8's Avatar
    wes_v8 is offline WES_VN
    04 Vz Sv6 6 speed
    Jun 2005
    Maitland near Newcaslte N.S.W
    yea i installed my elec antanna myself so u should be able 2 lol, all u have 2 do is jack ur car up at the front pass side, take the inner plastic off, and u can see what 2 do from there but like what other ppl have said thats what u do pretty easy job
    VN Executive S2
    Jul 2006
    I got a new aerial from K-Mart for $1!
  1. my first car 1991 VN LE
    By BUSTA in forum VN - VP - VG - VQ
    Last Post: 15-01-2009, 04:09 PM
  2. F/s 1991 Vn V6 Bt1
    By futronix in forum Vehicles For Sale
    Last Post: 04-12-2006, 06:47 PM
  3. replacing VS antenna
    By existentialist in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-11-2006, 07:02 PM
  4. Replacing Aerial on 1991 VN
    By tep_aus in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-08-2006, 11:49 AM
  5. 1991 Hsv Vn Ls ?
    By DF_Media in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-03-2005, 12:19 AM
