Results 1 to 16 of 16
Thread: Tapping comming from drivers side
    PaRaDoX's Avatar
    PaRaDoX is offline boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    Default Tapping comming from drivers side
    hey.. initially thought it was my steering rack, but my steering hasnt been compromised as a result of this....it used to be while turning left it made a tapping(can feel it and hear it), then it progressed to going forwards and turning left... it only occurs while going over 30-40km/h but i noticed the brakes squeal like a pig under 30km/h
    im beginning to think its one of the calipers as when braking the tapping disappears,
    its getting worse thats for sure.. i might retire the car untill i can figure out why...
    the master brake cyclinder isnt leaking and looks to be in good condition...
    i can get 2001 HSV calipers for free as my boss is getting bigger ones, would it be much work to modify them to fit?? was also considering upgrading to slotted rotors at the front.... i went with the cheapest possible pads and rotors over a year ago and they've done nothing but squeaked.. but now this sounds soo bad im embarrased
    anyone got ideas's??? cheers
    xcop5l's Avatar
    xcop5l is offline 4th year spanner spinner
    VN ex cop 5L
    Jun 2006
    ol' geelong vic
    it will most likley be brake shudder mine dose it in the rear
    Stato on the inside, berlina on the out side,5ltr under the bonnet,stockies all round...........that thing has to be a sleeper
    MY RIDES
    [SIGPIC][/SIGPIC]
    http://forums.justcommodores.com.au/...ad.php?t=41837
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    what would cause it??? a bunged cyclinder in the caliper??? or maybe warped rotors
    VP Lexcen commodore
    Jul 2006
    Ipswich Qld
    might be shot or loose wheel bearing . that will tap and will cause wheel shudder under braking.
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    hrm... any way to be certian??? should i take it to a shop to get diagnoised (i hate shops)
    im confident i could do the work my self finding the problem is another thing
    xcop5l's Avatar
    VN ex cop 5L
    Jun 2006
    ol' geelong vic
    yeah take it to a shop theyll be abil to help
    MY RIDES
    [SIGPIC][/SIGPIC]
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    hrmm at low speeds its non exsistant, dosnt matter if the cars in drive or netural..
    might trying killing the ignition while moving at say 60-70 see if its power related, and also will remove the wheel and take a squiz
    xcop5l's Avatar
    VN ex cop 5L
    Jun 2006
    ol' geelong vic
    dose the brake peddal vibrate when you brake from 100ks?
    MY RIDES
    [SIGPIC][/SIGPIC]
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    nope, i can feel it when i rest my foot on the foot rest (auto) and the chassis is vibrating feels like its comming from right behind the firewall near my feet
    xcop5l's Avatar
    VN ex cop 5L
    Jun 2006
    ol' geelong vic
    what about steering vibration under light braking
    MY RIDES
    [SIGPIC][/SIGPIC]
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    nope.... its the same when going straight and turning... does make a single light vibration when changing direction, but i believe thats normal
    VN Executive S2
    Jul 2006
    Tighten your wheel nuts!!
    nah, i reckon take your caliper off and try to move the rotor side to side, up and down and give it a spin to test the bearing. it could be a busted tie rod end, i stuffed one when i lowered my vl (hitting it with the hammer to get it out) and it made heaps of noise i had to change it straight away. if you hear a noise when turning left it would normally indicate right wheel bearing. and if the brakes squeal change your pads already!
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    nah pads squealed from pretty much a month after changing em.. got plans for probbly 14" slotted rotors that come with pads
    yeah i recon it would be the right wheel bearing as braking is un affected and so is steering..
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    Quote Originally Posted by mischf
    ohhh if only you knew how RIGHT you were....
    finally got round to ripping it apart (hadnt looked at it yet)
    noticed the wheel nutz WERNT TIGHT...
    i remembered back to last week where my mate was over and he put the wheel back on..... *slaps head*
    anyway tightened them and problem gone....
  15. #15
    VN Executive S2
    Jul 2006
    HA HA HA
    Excellent. It happened to a mate of mine's skyline... was the first thing i did.
  16. #16
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    yeah... just didnt get round to looking at it... had heaps of study to do oh well lucky it wasnt anything serious
  1. Drivers Side Mirror
    By parisian62 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-11-2007, 05:24 AM
  2. Drivers side boot leak.
    By _Mukas_ in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-06-2006, 08:41 AM
  3. Drivers side engine mont
    By youknowmelyricz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-08-2005, 12:08 AM
  4. VL Commodore drivers side door
    By huck0487 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 25-06-2005, 12:11 AM
  5. drivers side rear window
    By david41073 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-06-2005, 10:03 PM
