Page 1 of 2 12 LastLast
Results 1 to 25 of 28
Thread: fitting o2 sensor
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    Default fitting o2 sensor
    The NZ VN commies didn't have the o2 sensor fitted in the exhaust. if i fit the o2 sensor (the wiring is there for it) will it work or will i need to change the memcal also
    vp v6 commodore executive
    Aug 2006
    south island newzealand
    I too live in NZ and have no oxy sensor but want one someone help us.
    Strangly winaldl still gives me an O2 reading must be a calculated value from the memcal or ecu.Probably goes better without the O2 sensor changing the fuel mix anyway but I want lean cruize god dammit.
    Doctor Bob's Avatar
    Doctor Bob is offline Grandpa
    VT V6 Exec & VN V6 Exec
    May 2004
    Mornington Peninsula
    would need to know the code on the memcal to see. Some NZ calibrations have it disabled but the data list still shows it.
    Rob
    Apr 2006
    Auckland NZ
    what code should we be looking for on the memcal?
    Body by Holden, Soul by Brock
    the Legend will live forever
    Doctor Bob's Avatar
    May 2004
    just the delco sticker on the eprom.
    its a silver sticker with
    "DELCO" & a 4 letter 4 digit code on it
    post that for me & ill look it up
    Rob
    Aug 2006
    Doctor Bob's Avatar
    May 2004
    yep thats a specific NZ cal, made for leaded fuel
    you will need to get an aussie cal to get the oxy sensor working.
    do you know anyone with an eprom programmer to read off that memcal?
    i dont have it on file , be nice to add to my collection
    Rob
    Aug 2006
    Chears doctor bob you must have been sitting in front of your pc when I wrote that post super fast reply.Im in the process of getting a chip burner at the moment then I can read that bin for you.Should I just put the 3.8 hsv bin on my eprom for a start you think.Chears heaps.
    Doctor Bob's Avatar
    May 2004
    yep the SV3800 is a good starting point, when you get it read off email it to me rob@memcals.com
    download tuner pro & have a play with it
    Rob
    Aug 2006
    nice one rob will send it as soon as I can get me a burner.Get this thought hmmm where can I get a burner so went to the local comp store and asked if they could price me one all I got was a flat out no.They have never been that usefull actually,maybe I need a suit and tie.
    Apr 2006
    Auckland NZ
    Quote Originally Posted by spanners View Post
    try trade me, i think i saw an eprom burner on there the other day
    Aug 2006
    chears mate had a look cant find a burner yet need to goto city and just buy one off the shelf.Whats your memcal prom number immortality anything like mine.
    Apr 2006
    Auckland NZ
    sorry, haven't had a chance to look at it yet, i'd just finished putting all the interior bits back in when i started on this road and hadn't yet fouind the motivation to pul it out again. maybe this weekend
    Aug 2006
    Doctorbob that memcal above was out of my vp I just got my mate ecu after it sh** itself coolant temp said 30 degrees even after a new sensor used to cough off idle and smoke from too much fuel new ecu fixed that so ive got another memcal it is a vnv6 one APDL0288 if you can burn me a copy of the hsv3.8 chip ill send you the chip out of this one if you want it I just havnt got my burner yet.and cant read it or burn me something better than what ive got might even plug in the vn memcal into me vp I took the bellmouth out and it went better low down but think its starving for fuel up top cos ive got no O2 sensor its still feeding in the same amount of gas as it did with the bellmouth in it seams that the bellmouth is quite restrictive but I have put it back in incase it is running to lean I here that holden tuned them over rich to protect the engine a bit but I can tell its just not enough.
  15. #15
    Aug 2006
    bought an o2 sensor today hope its the right one seems to be a multi-fit kit for any car bosch 0 258 002 210 - 760 cost $90 searched the net but couldnt find out about it anyone know if it will be right I need a two wire one and this is a two wire one is there any difference or they all the same.
  16. #16
    Aug 2006
    put in my sensor works all good no problems getting it in and going .even displays o2 sensor data on winaldl without it activated in the tune .all wires were there ready to go.just experimenting with a few tunes at the moment cant wait for my burner to get here in a few days.
  17. #17
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    A sensor is a sensor. As long as it has the same number of wires then it will be OK.
  18. #18
    Apr 2006
    Auckland NZ
    i've got the ADPL memcal in my VN. haven't got around to the o2 sensor yet. mine is the single wire setup though. i need to find a few different tunes to suit with o2. i've got a couple of greenfoam's tunes but haven't got the HSV3.8 yet
  19. #19
    Aug 2006
    im running that vn memcal in my vp at the moment sucks the gas in the vp thats for sure been running the hsv3.8 as well doesnt suit vp to well i think.Does have some nice tweaks that make the car nicer to drive though.ive got the bin for it here somewhere.
  20. #20
    PaRaDoX's Avatar
    PaRaDoX is offline boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    if im correct and the wirings there, couldnt you just run APNX with a o2 sensor???
  21. #21
    Aug 2006
    yeah probably put any of the australian vn-vp v6 tunes in just to get going with the o2 sensor but I want to tune a memcal perfectly for my vp instead of the close enough factory setup.tried the hsv one havent tried anyone elses tunes probably wont even bother just gonna jump straight in to the tune in the vp allready.just bought another o2 sensor for my mates vn trident this time cost $80 nz got a two wire one even though it only needed a one wire one just to make sure it has a good earth.
  22. #22
    Aug 2006
    put o2 sensor and hsv3.8 tune in mates vns1 today.the o2 sensor wire was plugged into another wire that was earthed onto the bottom of the dfi unit.man does his vn crank now.
  23. #23
    Aug 2006
    immortality hurry up and get that o2 sensor my mate says your missing out on a good thing put the hsv3.8 tune in there for a start the gain is worth the cost of the sensor if you have a pod and decent exhaust.my mate says his goes mad compared to the nz vn tune I noticed the difference just backing out the drive.hes just done 400kms on his new tune saved quarter of a tank of gas compared to normal.does the same trip couple of times a week.we are gonna work on a better tune for his vn after my vp should team up on some testing and information sharing on how we can emprove the tune.two heads and two opinions are better one.
  24. #24
    Apr 2006
    Auckland NZ
    i hear ya, i gotta pull the header off on the passanger side and weld a threaded bung onto it forthe o2 sensor. where you get your sensors from part no? cheers
    edit. where you get your SV3800 memcal from, just tried my local holden wrecker and he didn't know what i was talking about.
  25. #25
    Aug 2006
    I get the sensors from my parts man have an account with him get good discount about $80-$90 have had one bosch one and one trident one both seam to work good time will tell how long they will last bosch part number above in previous post will post up the trident part number later for you the box is in my mates shed round the road the bosch one came with a flange with two bolt holes for another type of fitment if you drill a hole in your headers you could weld this flange over the hole and then youve got the right thread to screw it into.IOf you dont get a sensor with the flange I could post it up to you so you can weld it on.People have had trouble with the sensors not earthing properly so I only install two wire one to make sure theyve got a good earth about twenty dollars cheaper for a single wire one but id be going two wire if you have extractors.
  1. Fitting
    By soyaman in forum Jokes/Humour
    Last Post: 12-10-2007, 05:29 AM
  2. VN S1 Coolant sensor - Will a V8 sensor fit/work in a V6?
    By mulligan-can in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-05-2007, 09:08 AM
  3. Fitting a kit
    By 2_SeeK_U in forum General
    Last Post: 16-02-2005, 10:57 AM
  4. Fitting ABS
    By HQ_Kid in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-01-2005, 10:46 AM
  5. Fitting A POD
    By Hocney in forum VL Holden Commodore (1986 - 1988)
    Last Post: 09-06-2004, 04:48 PM
