My mum has a stock as VN V6 auto, that has basicly been rebuilt. Everything
on the car is new - engine, diff, cooling, elec., the LOT!
Anyway, last week, she had to get her 3rd tranny in the space of 4 years !!
At $750 each, its adding up, plus the hassle of being without wheels for afew days.
Having her doubts, the cars chassis was checked for allignment....all good !
Engine and box mounts......all good !!
Has anyone else had major probs with the TH700 ???![]()
Were they 2nd hand or rebuilt, how long was the warranty?
the quickest way to kill an auto is excessive heat but a stock car shouldn't have this problem unless someone is driving it and revving it whilst holding it with the brakes at the lights for a quick takeoff for long periods of time??
Well, im up to my 3rd gearbox. I cant say that the T700 is the best in the pack but she still goes ok...But all myne were 2nd hand gearboxes but still suposed to be ing ood condition. Rebuilt ones should be better then a new one.
Originally Posted by immortality
It is good to keep the auto fluid as cool as possible, so even if you dont do heavy towing, racing etc you can increase the life of the tranny and efficiency by fitting an oil cooler.
3rd tranny in 4 years? That terrible, I thought you should get at least 100000km out of an auto box. Especially one as simple in design as the TH700. Might be advantageous to fit an inline filter to the oil cooler line. Which just reminded me, Maybe the cooler line in the radiator is blocked if the radiator hasnt been changed recently.
Im not a complete idiot, some parts are still on backorder!
yeah you can get one of those S2 calais oil coolers from the wreckers that would help!!!
sounds like you should get it rebuilt with better quallity parts (stronger) reinforced, my Turbo 700 has been fine and i give it a flogging alot
i have 2 vn's. both auto
my stockish vn.... slips. when i floor it... whole car shakes... stand still take off turning at a intersection it slips bad (slips for approx 5sec).. while driving around a corner... it drops a gear and revs out going no where
my modified vn.... fitted with stage 2 shift kit.. did run good. however i did give it a bit of a trashin as my car had nos etc back in the day and doing burn outs etc (been removed due to defect now) and blew a flex plate. fixed problem, now 60,000kms later problems found are
turning a corner it drops a gear then changes up a gear and revs a bit. never used to. few months ago while doing a 1st to 2nd gear burnout at a u turn... car struggled to stay alive.. when in neutral it was alive.... but when in gear, lights dimmed and needed to gas it to keep it alive... days later it sorted itself out.. however when in gear not moving... it rattles... very loud.
a few days ago.. did a 1st to 2nd gear skid around a large round about (approx 60-70mtrs) and now gearbox has very loud vibrations and noise... while driving... 4th is shaky.. when off acceleration... has a vibrations and sounds. while going 100km/h car shakes and vibrates in a throbbing way and gear changes are not firm and quick nemore... however raced a vy last night and it still quicker than other 6's
im in need of a new motor and box.. but no1 in my town is interested to do a rb25det or a 2jz converstion...![]()
Hey guys, ive noticed that when some guy rebuilt my engine and all he didnt clip and bolt the tranny oil lines to the engine properly and they're kinda loose and they lean/rub on my pacemakers headers, could this be ****ing my tranny!
Possibly as the tranny fluid should be as cool as possible and the exhaust would (obviously) heat it up. Also you dont want it to rub thru and set the fluid alight.
This sounds just like my old tranny just before it died. Reved and wouldn't move dropped gears and then lost gears 3-4. I could be going down the road and if it went into 3rd it would just rev out and not move.Originally Posted by prince_dj666
Also your vibrations i think are common with many V6's. I had at times a bad vibration straight through the car it shook all over the place. Sometimes when going hard it vibrated and sometimes slowing down and going around a corner it would vibrate really bad when pulling away in 2nd. I had a crack in the tailshaft and once replaced no more vibrations. Most of the tailshafts in the V6's get out of balance easy to.
Originally Posted by Yoda
Originally Posted by SlickHolden
i know what u mean bout the vibrations... but its a new abnormal vibration...
Does the middle of your dash vibrate also? Sounds like at times it back at the diff?.Originally Posted by prince_dj666
whole car vibrates... u can feel it in the pedals, steering wheel etc. u can hear the throbbing vibrating sound under passsenger n drivers seat. :S
It sounds like a unbalanced tail shaft to me they can get pretty bad when they are gone.
check the centre hanger bearing and rubber support, when this goes it's just like having an outa balance shaft. if you thrash your auto always fit a bigger trans cooler. Holden even recommend their extra trans cooler kit if you use the car for a lot of towing etc it's just another little radiator fitted in front of the big radiator and after the fluid goes through the radiator/trans cooler it then goes through the extra cooler before going back to the trans. how long since you last had the tranny serviced, full flush etc old fluid become air-rated and that leads to slippage as the fluid can't provide full presure on the servos and you have a stuffed tranny in no time at all
Body by Holden, Soul by Brock
the Legend will live forever
Yes they can get horrid! It has happened to be before, the vibrations were shocking from the tailshaft. I found out that it wasnt the Universal joint, but the flex joint that was all ####ed up. just get a new tailshaft and it was gone forever!Originally Posted by SlickHolden
last night... 1st gear slips, till it hits 2nd... then it moves but then at higher revs it slips again.... in 4th it shakes the whole car. gearbox has had ittime for a new car. been thinking of a na vl 5speed.. i dont really wanna spend too much on the vn nemore fixing it....
You could pick one up for $1100, Or convert it to 5 speed, Is it a problem child the car?.Originally Posted by prince_dj666
Same here new tailshaft and it's vibration proofOriginally Posted by Mack
I didn't know myn was cracked
i fixed the problem... i went and bought myself a 5speed vl turbo with a T03/04 turbo.. much more fun...
Ooooh, how is the car mate, good?
hell yeah! one of the powerful cars i have own. first revs out quick, second it skids all the way, hit third and still skids for abit then pick up traction... i can actually feel it the car twist (a lil bit) as u see the left front pick up. the bov sounds excellent too.. not a "tssshh" sound. but a "choo choo chooooo". i checked to make sure if it had decent tread cos of the wheel spins. but they are decent falken with 90%tread. so i was shocked. i had a rb20det 180sx. and this vl feels way more stronger than it. had nos in the vn too... but the vn had a more different power curve whereas the vl has a boost rush power delivery. now i have to get rid of my other cars, as atm i have 3 commodores... :S
