Page 1 of 2 12 LastLast
Results 1 to 25 of 35
Thread: Requesting help from VN/VP owners
    Troy711's Avatar
    Troy711 is offline Moderator Puppeh
    2007 WM Statesman
    Dec 2003
    Canberra, ACT
    Blog Entries
    Default Requesting help from VN/VP owners
    as juzza did with the VB/K and VL forum, i will make a sticky thread with FAQs about each model. i am asking for people to post as many common questions as they can think of so i can start this off.
    you dont need to worry about posting a link to the question, just what it is and i can do the searching myself. i want to try and get as many as possible to try and help new and existing users.
    thank you
    jack.mc's Avatar
    jack.mc is offline Nothing witty to say :(
    VN Vacationer
    May 2005
    Sydney, NSW
    OK, heres a few ideas:
    stereo install guide
    CAI installation
    a "cheap power mods" section - like that exists!
    Am I on the right track?
    Troy711's Avatar
    2007 WM Statesman
    Dec 2003
    Canberra, ACT
    Blog Entries
    yep, stuff like that is great. also a list of common and frequent problems would help
    Shortstuff's Avatar
    Shortstuff is offline Random
    1995 VR II V6 Wagon
    May 2006
    Differences between S1 and S2 engines on the VN has come up a few times recently. Injector cleaning / replacement too. And tapping noises from the engine is a common one!
    Whoever said 'There is no substitute for cubes' had obviously never heard of Jet power
    mouce's Avatar
    mouce is offline Physics Geek
    VN V6 Series 1 Executive Sedan
    Jul 2005
    Crank angle sensor replacement, and fuel pump replacement.
    For anyone feeling adventurous there's always the rear main seal leak
    Gravity is proof that nature keeps getting us down.
    Pretender's Avatar
    Pretender is offline Brain function fading .
    Pajero LWB Wagon, Power/economy what's that ???
    Oct 2005
    Sunny Rockingham WA
    How to test CAS, Coil Pack and DFI module.
    Non functioning guages
    Boot leaks
    Ignition barrel removal/replacement
    Installing later model parts
    Never
    $50.00 paid for each answer to a post of mine.
    Please note cheques will not be honoured
    Sep 2005
    Adelaide, South Australia
    Best ways to gain power without breaking the bank ...
    What is the best way to lower a car compared to an angle grinder ...
    How to setup the front and rear suspension to drivers needs ...
    A way to change door trims over to VR/VS style with the vent on the door card ...
    How to do a basic setup for a boot install ...
    What is needed in a V6 to allow forced induction ...
    How to repair the speedo since it dont work ...
    How to change the lights in the dash to LED's ...
    How to install airbag suspension ...
    How to install airbags in the steering wheel and put it on the vn with full working circuit ...
    theres a start yeah ?
    fu2's Avatar
    fu2
    fu2 is offline The Man With No Name
    VP Berlina II - MY10 VE SV6 Ute - VH SL/E
    Jul 2004
    o2 sensor problems
    fiting o2 sensor
    fault codes
    vt+ seats in vn/p
    there just some off the top of my head
    Boonz's Avatar
    Boonz is offline the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    common defects, legal ride heights, VT shifter on the VN/P, VR door pods and map pocket installation, parcel shelf mods,
    SweetWagon's Avatar
    SweetWagon is offline booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    xcop5l's Avatar
    xcop5l is offline 4th year spanner spinner
    VN ex cop 5L
    Jun 2006
    ol' geelong vic
    heater core removal and assembly
    heater fan risistor location, removal assembly
    orignal power outputs of the v6 and v8
    tyres : max width max size ect
    head rest lcd instalation
    thats all ive got for now
    Stato on the inside, berlina on the out side,5ltr under the bonnet,stockies all round...........that thing has to be a sleeper
    MY RIDES
    [SIGPIC][/SIGPIC]
    http://forums.justcommodores.com.au/...ad.php?t=41837
    Boonz's Avatar
    Jul 2005
    anton1o's Avatar
    anton1o is offline [GMHVN6]
    VN 6 Berlina '90
    Jan 2005
    West Subs,Melbourne
    Quote Originally Posted by stocko_VH
    Quote Originally Posted by jack.mcintyre
    Check this thread for all Pricing/Power Gains on parts for VN-VP V6-V8.. It was de-stickied some time ago =/
    Thread dedicated to Modifcations
    ride; [GMHVN6] Project Streeter - VN Berlina '90 mods; 65mm throttle-body / Cold Air Intake / 8mm Ignition Leads / Exhaust
    future; Extractors , Cam currently; 101.2rwkw mission; 110rwkw
    SweetWagon's Avatar
    Jan 2006
    Springwood NSW
    ALDL diagnostic trick, removing steering wheel, replacing harmonic balancer, suspension guide
  15. #15
    PaRaDoX's Avatar
    PaRaDoX is offline boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    changing starter motor
    changing shocks springs
    BASIC GO FASTER CHIP by foam good good forgotten thread
    Head porting thread
    cleaning Throttle body
    how to open %100 throttle body by foam again
    fushing coolant
    if there is one on oil changes
    just some idea's
  16. #16
    xcop5l's Avatar
    VN ex cop 5L
    Jun 2006
    ol' geelong vic
    manual conversion
    torque wrench settings for heads big ends mains ect
    guide to replacing rope seals (rear main)
    MY RIDES
    [SIGPIC][/SIGPIC]
  17. #17
    Shanoqueeb Guest
  18. #18
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
  19. #19
    Sep 2005
    A guide to fitting a newer ignition barrel (VY-VZ) to a VN Commodore
    A guide including oictures on how to take out door handles and replace.
    A guide on installing VY-VZ door handle locks into the VN handles including boot lock.
    Also
    How to get passed the damn stretched bonnet cable, adjust or repair.
  20. #20
    'Ruby' 1991 VN Exec & '98 Proton M21 Coupe
    Chain Reaction Champion!
    Feb 2006
    North Tassie
    If all those get incorporated, no one will ever need to ask a question again! And I can't believe that it hasn't been said yet....
    What to do bout that damn sagging roof lining!!"
    :: hakhawk :: says:
    im a geek by day
    :: hakhawk :: says:
    a mass/axe murderer by night
    :: hakhawk :: says:
    and a rabbit sometimes
    I'm only nice to one person per day. Today is not your day....
    Tomorrow doesn't look good either.
    God must love stupid people, He made so many.
  21. #21
    VP Executive R-spec
    Jan 2005
    I'd like to see a thread about removing things you dont need. If I could loose 50kgs out of my VP after reading a thread I'd be happy
  22. #22
    91 lexcen vn S2
    Nov 2005
    heathmont
    there are plenty of questions being asked here but where are the answers...this thread has heaps of awesome stuff that i will be jumping at the oppurtunity to do to the vn but i cant find any threads on her yet.....wats happening with it?
    YOU KNOW WHAT THEY SAY.......WAIT......NO I DONT
  23. #23
    1991 vn series 2 exec [URMONY] & 93 vp calais
    Apr 2006
    melb
    Quote Originally Posted by 1vngal View Post
    call me and my mate once you buy a lightweight blanket and we'll fix it up :P
    ok now more things to get the help on and i know some will sound stupid
    HOW TOO'S
    change 1 and 2 pice tail shaft uni's and centre bearings
    flush radiator
    thermostat
    powersteering rack
    backseat removal refitting
    fix air and water leaks (in interior such as how to find them and patch up) eg biggest one water leak into the boot
    remove centre console and dash parts without breaking clips
    or another like that im sure everyones done remove front speaker casing without breaking them
    wiper motor removal refit
    fuel rail
    plugleads sequence
    convert from normal auto to shiftkitted auto
    diff and diff centres
    powersteering pump,fuel pump,water pump, removal refitting
    now as not all of us are experts or might even be new to our vn/vg/vp/vq
    WHERE THINGS ARE LOCATED
    all pumps
    CAS
    ECU
    (silly i know but) fuses
    heater core
    wiper motor
    thermostat
    (a good one for cars with no tacho wanting to add one) where is the wire and connection ports for the electri speed reading (theres a lil wire in the loom under the bonnet to the left side of the car (right looking from front of car back with popped bonnet) its not connected to anything thats where it is
    thats about all i can think of for now hope that helps troy
    ~~Nic~ says:
    yeah feel dick tho
  24. #24
    VL Calais Turbo
    Mar 2006
    Australia SA
    parcel shelf removal/rear seat removal
    stereo install
    door trim removal (sikaflex)
  25. #25
    5 speed v6 vn commodore
    Dec 2006
    waroona WA
    a general flow chart for common vn commodore faults
  1. Requesting help from VT/VX owners
    By Troy711 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-12-2007, 04:12 PM
  2. Requesting help from VR/VS owners
    By Troy711 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-11-2007, 11:41 AM
  3. Requesting help from VY owners
    By Troy711 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 26-04-2007, 07:33 AM
  4. HSV Owners...
    By NORTI in forum General
    Last Post: 13-04-2006, 10:32 AM
