how can i get the trim passed the air vent on drivers side the rubber want go passed it i cant work out how to get it in please help thanks hoon1
have you got a pic cause i dont understand what you mean
Adam
have a look were the door trim runs on the vn drivers side the top vent
can u circle it in this pic?
or havent i got it in the pic
Adam
If its the door seal/trim bit you might have to take the vent side off by undoing the 2 screws on the side and the one from inside under the fuse cover door.Then take the 4 screws out that secure the vent itself from the dash edge.They are pretty recessed so you need a screwdriver with a bit longer shaft.When you have all the screws out it will be very loose if it shows some resistance keep looking for a screw that you have missed.
With that off the weatherstrip door seal should just come off.
This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain
......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
thanks markovr im trying to put one on ill give that a go thanks
