Results 1 to 14 of 14
Thread: MAP Sensor help
    VN V6 And XA 351
    Aug 2005
    Warwick QLD
    Default MAP Sensor or Not Please help my daughter is sick
    hi guys my car is playing up real bad i cheacked codes and got Code 33 - Manifold Absolute Pressure Sensor (MAP) - Voltage Too High, sorry to be a pain but i need to fix this ASAP as my daughter is really sick and im affraid i may have to take her to hospital during the night
    Any help would be great
    Jay
    Last edited by Jaym; 03-09-2006 at 06:26 PM. Reason: MAP Sensor or Not Please help my daughter is sick
    missus (in more ways than one)
    Sep 2005
    that means you need to replace the sensor,, please someone correct me if i'm wrong but i think it's behing the alternator, head down to bursons and ask for one and it should just be a screw in and plug in job, plus removing the alternator which is 2 bolts and a few power lugs, hpe it all works out for ya mate
    mouce's Avatar
    mouce is offline Physics Geek
    VN V6 Series 1 Executive Sedan
    Jul 2005
    MAP sensor is the black rectangular box bolted to the firewall. Stand at the front of the car with the bonnet open, look down the length of the big black plastic intake pipe on the passengers side, you'll see a black rectangle at the other end of it (not attached to it). The box should have one electrical connector, and one hose (running to the throttle body).
    Hope your daughter comes good soon.
    Gravity is proof that nature keeps getting us down.
    VN V6 And XA 351
    Aug 2005
    Warwick QLD
    sorry yes i know what a map sensor is, i just wanted to know if this was a common proabalem and is there a cheap fix for the next 24 hours, turns out my daughter had to stay in hospital over night, im on my way back up there now, just hard to drive with a dead map sensor, and yes i reset the ecu every time i park the car
    cheers
    mouce's Avatar
    Jul 2005
    I don't think there's any easy way to fix it other than replacing it. If you've got a wreckers near by you should be able to just get a second hand one from there. Takes bugger all to swap it over.
    As for being a common problem, I can't say that I hear of it all that often, but then again, I'm not a mechanic either.
    xcop5l's Avatar
    xcop5l is offline 4th year spanner spinner
    VN ex cop 5L
    Jun 2006
    ol' geelong vic
    ive seen it a bit.
    as for it not working it will make the car run extreemly rich as it will think its at open throttle all the time so fuel consumption will hit the roof.
    theres no quick fix for this so you can just replace it but id recomed replacing the vacume hose off the map sensor to the intalk as well as they perrish and split.
    Also ckeck all other vacume hoses as well. because they can split and perrish aswell
    Stato on the inside, berlina on the out side,5ltr under the bonnet,stockies all round...........that thing has to be a sleeper
    MY RIDES
    [SIGPIC][/SIGPIC]
    http://forums.justcommodores.com.au/...ad.php?t=41837
    xcop5l's Avatar
    VN ex cop 5L
    Jun 2006
    ol' geelong vic
    Quote Originally Posted by CSL
    i think thats the coolant temp sensor your describing
    MY RIDES
    [SIGPIC][/SIGPIC]
    VN V6 And XA 351
    Aug 2005
    Warwick QLD
    ok guys i brought my daughter home from hospital car went ok.. but then i had to go get my other daughter and the car broke down but wont start anymore, well it starts coughs and farts for a few seconds then stalls, i changed map sensor made no differnce, i really need my car as my daughter has to go back to hospital at 7 in the morning to see the doc
    VN Executive S2
    Jul 2006
    VN V6 And XA 351
    Aug 2005
    Warwick QLD
    VN Executive S2
    Jul 2006
    PaRaDoX's Avatar
    PaRaDoX is offline boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    Quote Originally Posted by mischf
    nasty........
    you deserved it...
    ok do another self diag,
    theres 3 things that usually go at this age that cause the same issue
    1. DFI moduel (under coils on the coil pack unit)
    2. CSA (crank angle sensor)
    3. ECU
    i had a faulty ECU that told me my CSA was dead, then told me my o2 sensor was rooted... turned out the CSA was fine, and same with the o2 sensor.. DFI moduel and ECU went..
    i know this may sound silly man, but check all the ignition leads... when it coughs and splatters its not getting enough spark to detonate the fuel properly and equally, one might be loose and the spark plug might only be getting %50 spark, other than that sounds like a coil pack issue maybe you blew a coil, easiest way is to borrow a mates coil packs to find out... sucks you need the car operation and need it now...
    do more testing...
    and we'll try to help, hope your daughter gets better man
    xcop5l's Avatar
    VN ex cop 5L
    Jun 2006
    ol' geelong vic
    dont you mean cas???
    MY RIDES
    [SIGPIC][/SIGPIC]
    mouce's Avatar
    Jul 2005
    Could also be the fuel pump playing up now...it can cough and splutter because it's not got enough fuel pressure to run.
    When my pump died, it would only JUST idle, but only for a few second before it died.
    Check your fuel filter, and pump.
  1. VN S1 Coolant sensor - Will a V8 sensor fit/work in a V6?
    By mulligan-can in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-05-2007, 09:08 AM
  2. O2 sensor
    By CANYONERO in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-04-2006, 06:52 PM
  3. o2 sensor
    By Fully in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-09-2005, 10:46 PM
  4. cam sensor
    By I LIKE COMMODORES in forum V6 Development And Modification
    Last Post: 20-09-2005, 11:39 AM
  5. o2 sensor - how much, where from
    By jack.mc in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-08-2005, 07:25 PM
