Results 1 to 5 of 5
Thread: Stupid exhaust bandage
    VN-Series I-6-90
    Apr 2006
    Default Stupid exhaust bandage
    Hey peoples for the umptyth time this year my exhaust bandage has blown out. I have the exhaust badaged at the join of the two pipes that come down from the engine into the "Y" piece b4 the cat.
    One pipe like slides onto the other one and has two slices 180 degrees appart and like say 4-5cm down the pipe. when the two are together i cant get the inner tube to slide far enough into the sliced one to seal. So i am left with two like 2-3mm holes at the end of the slices. The badage stuff that ive brought just seams to pussy to take it and is a pain to put on as it has the stickyness of a piece of wet cloth b4 it cures (with the heat of the exhuast which is dumb cause you dont want to have air trying to force out of the piss poor sticky stuff while its supposed to be curing). So your supposed to tie it up with this wire they give you... bah i hate it ... I HATE IT lol
    So what i was wondering can i go like bush mechanic on it and get a tin can from like spaghetti tin (not like from VB / NEW as I expect this is what you thought if first when i said tin can... lol) and get a strip to cover the hole would it take the heat???
    I was thinking of smeering it up with exhaust cement and then use the two clamps i have on the exhaust at the moment and crush the fcker on there good and proper..... chances of success???
    I know it could probably be welded up but i am a bit apprehensive about doing that incase it made getting the exhasut off a pain in the arse and i would have to pull it out to get a weld right around aswell...
    Its just that i have exhaust cement and tin cans, and with my welding skills id end up with more holes or bigger holes than i started with, so this would be my last attempt to have some sort of semi-permanent fix.
    Anyone shoot it down b4 i start and go and get all itchy crawlin around on the lawn??
    Cheers Apoc.
    xcop5l's Avatar
    xcop5l is offline 4th year spanner spinner
    VN ex cop 5L
    Jun 2006
    ol' geelong vic
    weld it
    if you dont have a welder take it in and get it welded
    sooo much eayser than fkn round under the car with that bandage sheit
    Stato on the inside, berlina on the out side,5ltr under the bonnet,stockies all round...........that thing has to be a sleeper
    MY RIDES
    [SIGPIC][/SIGPIC]
    http://forums.justcommodores.com.au/...ad.php?t=41837
    S Pack's Avatar
    S Pack is offline Topped out @ 230kph
    Mercedes E-Class 2007, E220 CDI Wagon
    Jul 2005
    Germany, Europe
    sorta on the topic but why do my gaskets on my extractors keep blowing......ive tried the paper ones and the metal ones....the exhaust shop is baffled......i dont drive it like a ferrari either
    xcop5l's Avatar
    VN ex cop 5L
    Jun 2006
    ol' geelong vic
    they are most likely out of shape
    MY RIDES
    [SIGPIC][/SIGPIC]
    VZ S
    Sep 2005
    Queensland
    why not just take it to an exhaust shop and get it fixed properly & be done with it
  1. stupid V6... help plz
    By SIG-054 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-08-2006, 05:12 PM
  2. Stupid Driveways and Stupid Gutters
    By Miss-E in forum General
    Last Post: 09-08-2006, 02:03 PM
  3. i must have done something stupid!
    By rbrtm in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-03-2006, 04:06 PM
  4. Stupid Stupid Question
    By habro in forum General
    Last Post: 24-09-2005, 11:51 AM
  5. stupid Q's
    By NVE_069 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 04-03-2005, 11:58 PM
