Results 1 to 6 of 6
Thread: vs tacho dash cluster into a vp??
    Matt_vp's Avatar
    Matt_vp is offline Donating Member
    vy lumina v6 A4
    Jan 2006
    Gladstone Qld
    Default vs tacho dash cluster into a vp??
    i got a tacho dash out of a vs for free and was wondering if i could modify it to fit into my vp exec?
    Matt_vp's Avatar
    vy lumina v6 A4
    Jan 2006
    Gladstone Qld
    Default all good now
    i worked it out all i had to do was swap the back casing with the green plastic stuff on it.
    HATER VP Guest
    fazz1977's Avatar
    fazz1977 is offline myspace.com/fazz_himself
    1992 VP Executive Wagon, L27 V6 3800
    Aug 2005
    Frankghanistan, Melbourne, VIC
    I did it. I pulled the tacho and temp/fuel gauges out and fitted them to the VP Lvl1 dash PCB. Works a treat. Forget the naysayers, my car is living proof.
    If you whack it straight it 2 of the connections short to 12v and it cooks the VS PCB.
    Life's Grouse in Frankston South!
    Phoenix21's Avatar
    Phoenix21 is offline Donating Member
    93 VR, 97 VT, 95 Statesman
    Feb 2006
    Crime bourne, Vic :P
    fazz1977's Avatar
    Aug 2005
    Nice work.
    See, it can be done... *mumbles something about negative attitudes*
LinkBacks (?)
  1. 25-02-2008, 03:24 PM
  1. Dash with tacho fit into dash w/out tacho and work????
    By Jamie_87 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-11-2007, 09:21 PM
  2. Swapping VR L2 dash cluster with VS Stato L3 Cluster
    By wheredoesthisgo in forum Electrical Wiring / Questions
    Last Post: 07-04-2007, 03:28 PM
  3. Will a tacho from a L2 fit L3 Cluster
    By chopsy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-07-2006, 10:26 PM
  4. Changing a VP standard dash to a Tacho Dash
    By Madhouse_Dave in forum Electrical Wiring / Questions
    Last Post: 01-07-2005, 11:35 AM
  5. vl tacho cluster into sl vl
    By creig451 in forum Electrical Wiring / Questions
    Last Post: 05-09-2004, 02:09 PM
