Results 1 to 4 of 4
Thread: Freakin steering wheel stuck on
    VN Executive S2
    Jul 2006
    Angry Freakin steering wheel stuck on
    I'm trying to get my steering wheel off it's got cancer (lumps from the sun). The bastard won't come off, i bought a $12 puller from autobarn and it fits well but the thread came off one of the bolts and it popped out when i was trying to pull it. Its tighter than a 12 year old are they all like that??
    And another Q:
    Where can I get brand new door rubbers from?
    Jun 2005
    yep pretty much. takes a bit of work to get those things off
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
    xcop5l's Avatar
    xcop5l is offline 4th year spanner spinner
    VN ex cop 5L
    Jun 2006
    ol' geelong vic
    clarke rubber has door seals
    with the steering wheel you need 2 people one has to sit in the car andd pull back on the wheel hard and wiggel it from side to side and the other needs to tap the steering shaft with a hammer not too hard as you may stuff the bearing
    NOTE : leave the nut on so its level with the shaft because they tend to come off fast and cause facial damage lol also so you dont damage the thread on the shaft
    Stato on the inside, berlina on the out side,5ltr under the bonnet,stockies all round...........that thing has to be a sleeper
    MY RIDES
    [SIGPIC][/SIGPIC]
    http://forums.justcommodores.com.au/...ad.php?t=41837
    VN Caladore
    Aug 2006
    I had the same problem with mine.. But with the wheel puller and some little bashes on each side, it helped.
    You have to remember also, with the VN wheel, there is 2 (or it may only be 1) screws that go through the metal plate in the horn, and actually connect to the column. So if you don't take that 1 or 2 screws out, even with a wheel puller you wont get it off...
    I also used a smaller bolt for the ones that you screw in to support the puller.. I found the ones supplied were just a little bigger and was not as solid...
    I spend too much money on my cars & bike
    Click me to see my ride
  1. Boss kits for VT steering wheels to fit a VZ/VY steering wheel?
    By nEb. in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-12-2011, 07:28 PM
  2. Steering wheel
    By Johnno.o in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-10-2007, 04:38 PM
  3. VX SII steering getting stuck mid turn....HELP!!!!!
    By MoSkA in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-04-2007, 06:43 PM
  4. steering wheel vq
    By myvq5ltr in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-12-2006, 09:23 PM
  5. Your thoughts on replacing steering wheel with airbag to a MOMO wheel....
    By *VOLATILE* in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-02-2006, 08:36 AM
