hi i got a silly request
i have 2 vn's a sedan and wgn now the throttle on the sedan is so nice and soft to use where my wagon is really hard compare to the sedan is there any ways to make the wgn pedal soft to use ( if u know what i mean ) like my sedans
i think im getting what u say... i have a similar problem with my car ever since i put on the 65mm throttle body off a v8, it use to be an easy pedal now it has gone really stiff, so maybe they used stiffer springs in the v8s?? but yeh, i dont know how to fix it just yet, im getting sort of use to it.
try cleaning the throttle body with carbie cleaner
also the cables start to bind after exseive use and feel tight so try changing that
Stato on the inside, berlina on the out side,5ltr under the bonnet,stockies all round...........that thing has to be a sleeper
MY RIDES
[SIGPIC][/SIGPIC]
http://forums.justcommodores.com.au/...ad.php?t=41837
had the same problem, turned out to be the throttle cable was worn and coming apart
thx was the cable easy to replace
they are a little fiddely at the peddal but other than that they are easy
MY RIDES
[SIGPIC][/SIGPIC]
