Results 1 to 22 of 22
Thread: engine cutting out , where to start guru's???
    VN
    Apr 2005
    Default engine cutting out , where to start guru's???
    So Im driving home the other night and the engine cuts out. I come to a stop, re start it, travel down the road for a minute, happens again. I keep repeating this till I get home.
    I let it rest for a bit and went out again, it seemed ok, no more cutting out of the engine.
    Today in my job I did another 160kms in it, the engine DIDNT cut out once.
    Obviously something must have caused it, or is wrong, but I have no idea where to start even thinking where the problem might be.
    I did have a slight water leak that was causing temp. to run higher than normal by a bit, but I fixed that and its all good now. But I cant see this having anything to do with it. What do you think? thank you.
    SweetWagon's Avatar
    SweetWagon is offline booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    J_D
    J_D is offline
    VN S1 and VS V8 Statesman
    Jul 2006
    Ipswich. QLD
    Does it start straight away after stopping or do you have to wait a few minutes.
    Im not a complete idiot, some parts are still on backorder!
    VN
    Apr 2005
    started straight away after each time it cut out, once I came to a stop of course.Could have cut out up to ten times possibly!
    CAS, if its at fault, whats one of em worth approx?
    m3taL's Avatar
    m3taL is offline For what its worth.....
    88` S1 VN, 5spd & 94' VR Wagon
    Aug 2006
    Bendigo, Vic
    Woha... Mine done the same thing about 20 mins ago.... had to wait bout a minute to start it again.... then it ran fine til the next set of lights n kaput then same thing bout a minute again n it got me home.... just about to go trip some codes.... come to think of it i put a new themostat and Coolent temp sensor in the other day too....
    VN
    Apr 2005
    no shit ! :0)
    f you could let me know what you come up with that would be muchly appreciated. I got very little idea car wise ...
    PaRaDoX's Avatar
    PaRaDoX is offline boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    everyone says CAS,
    could be the DFI moduel aswell... as they get quite alot of heat as they're bolted to the engine
    so its either the CAS or DFI moduel
    i had to replace both before i found my problem
    VN
    Apr 2005
    JD
    JD is offline Donating Member
    VS Berlina
    Aug 2006
    Deep South, SA
    what about fuel line blockage perhaps?
    fuel starvation can stall a car pretty quick
    We got rep back, yaaay!
    m3taL's Avatar
    Aug 2006
    Bendigo, Vic
    comtim: did u check ur ECU codes???
    My Saga Continues..........
    so i rest my ecu, then went for a cruise...... and then it happened 5 times it took me to get bout 1k home.... worse this time than last. i went to the servo then out of it bout 20 mtrs and kaput.... came home and only pulled Code 15 out of the ecu and thats cos i put a new frikken Coolent temp sensor in on sat and i reckon the dick at repco gave me the wrong one as he didnt know wtf he was doing (was bout 15 and didnt know what a 88 s1 vn v6 was.....) so i will be taking it back and shovin it up his a$$.
    My question is could it be that that is making my car be a biatch?? it seems to me that its Fuel as if it was CAS or DFI it would come up in the Fault codes??
    im lost.......
    J_D
    J_D is offline
    Jul 2006
    Ipswich. QLD
    Quote Originally Posted by comtim
    is a CAS a crank angle sensor? And what does it do ?
    The crank angle sensor tells the computer where the engine is in the combustion cycle so the computer knows when to fire the spark plugs and the injectors. Usually the CAS develops a crack in it and the expansion due to heat causes a break in the continuity of the sensor and the engine stops. After the engine stops the sensor cools down and reconnects so the engine will start again. If the engine doesnt start for a few minutes after stopping it is the CAS. The easy way to test this is to pour water on the CAS (located behind the crankshaft pulley) when it stops and if it starts straight away it stuffed.
    J_D
    J_D is offline
    Jul 2006
    Ipswich. QLD
    Quote Originally Posted by m3taL
    im lost.......
    Did you hold it at 3000rpm for 10secs on the first start after resetting the ECU?
    m3taL's Avatar
    Aug 2006
    Bendigo, Vic
    Quote Originally Posted by J_D
    Yup Would a Stuffed CAS Show up in Diagnotic Code?? or not?
    SweetWagon's Avatar
    Jan 2006
    Springwood NSW
    Yes it would show up as code 41
  15. #15
    m3taL's Avatar
    Aug 2006
    Bendigo, Vic
    Damnshit its not that then.......... i will get a propper Coolent temp sensor and clear that code and get a CLear 12 then go for another spin and see if it faults again i am guessing and its sounding a lot like a Fuel pump.....
    Lil bit of car history. It has been sitting for around 10 months dont think it was driven not sure if it was started i will contact the owner and find out.... is there anyway i can test the fuel pump?? or well i guess it will just Die sooner or later its the only thing i can think it could be. would the car sitting Rot a fuel pump??
    and does anyone know what one is worth maybe i will just get a new one and if its not it i will just keep the oldie as a spare if i need it.
  16. #16
    SweetWagon's Avatar
    Jan 2006
    Springwood NSW
    Try clearing the codes now and go for another drive to see what it records. A coolant temp sensor would not cause it to stall, it would only make it run rich at the worst.
    Sitting around for 10 months could cause alot of probs.
  17. #17
    VN
    Apr 2005
    I actually dont know how to measure codes. Can someone point me towards some info on how to do this ? That would help alot.
    Since the orginal problem in the first thread, I have done 4ookms and it hasnt stalled again yet. Go figure! It really has me on edge when driving !
  18. #18
    VN Commodore
    Feb 2006
    i bought some cheap fuel in melbourne once. it was fine for the first 2.5 hours then my cars kept dieing.. i kept starting it and going a bit further. finally i got home and put more fuel in it. so i don't know if it was dirty fuel or what. but it never ever did it agian.. could be the same sort of thing..
  19. #19
    SweetWagon's Avatar
    Jan 2006
    Springwood NSW
    Here you go, this should help you out - Click Here
  20. #20
    -VnExEc-'s Avatar
    -VnExEc- is offline CommyChick
    85 VK berlina, 96 vs ss
    Aug 2005
    auckland, NZ
    My car used to do the exact same thing.. i thort it would of been the CAS or maybe fuel pump.I took it 2 an auto electrician, no codes showed up, and he culdnt find anything wrong for 2 days, except for a leaking coil pack.Wether or not this was the actual cause, im not too sure.. but 1 brand new coil pack later and it hasnt happened since i got it back
  21. #21
    m3taL's Avatar
    Aug 2006
    Bendigo, Vic
    My baby is better
    i dunno wtf is goin on but all my Ecu codes have cleared i reset the ecu again then went for a drive, then kept driving.... then went from the east to the west and back.. done bout 400ks this weekend in it... Done Airfilter/Plugs/leads today and she is runnin even better now...... Weird cars they are
    m3taL... for what its worth...
    http://s92.photobucket.com/albums/l9...rrent=vn-3.jpg
    My Ride
    88' VN 3.8 5spd, Custom CAi, 2.5 High-flow zaust && Foaming Tune!!!
    Turbo Manifolds and Plumbing Near completion!
    Family Ride:
    2007 Kia Grand Carnival Lux Model
  22. #22
    VR Berlina V6
    Sep 2005
    orange
    Quote Originally Posted by defa
    Same with me, VR V6. Tried the ethenol fuel and exactly what you said. I put a bottle of metho in the tank and hey presto!
  1. Engine cutting out!
    By bertusmcspurtus in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 13-02-2007, 03:11 PM
  2. Engine cutting out on gear upshift (auto)
    By red131 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 27-09-2006, 11:43 AM
  3. Engine Cutting Out
    By gone_nutz13 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-06-2006, 01:38 PM
  4. Engine Keeps cutting out
    By tommo824 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-01-2006, 06:03 PM
  5. Cutting through engine bay?
    By G4orce in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-12-2005, 04:02 PM
