Results 1 to 5 of 5
Thread: I gotsa few questions
    dergib Guest
    Talking I gotsa few questions
    I have a vp excutive v6 and was just wondering if a vs v8 front crossmember would just bolt straight in as i have a wrecked ss and a brand new 5 litre and auto Another quick question does the dash outta the vs need any modification to fit into the vp?? if so any help would be greatly appreciated...
    thanx...
    1991_Vn2nV's Avatar
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    Dash from a VS fits straight in but you need the door trims as well because of the way the dash continues on with the air con vents which are located on the VS door trims...
    VN series II custom :) and VZ exec
    May 2005
    Mildura
    dsh should fit, but cluster wont work as its different to VP, as for the xmember, it should be a straight fit,
    dergib Guest
    thanx heaps i got door trims as well its pretty much a complete car. should i use the vp or vs wiring loom???
    1991_Vn2nV's Avatar
    Mar 2006
    Cluster is fine, just change the back of it from the green to the black (forget which is which) from the VS one to the VP one.
  1. CPI lpg questions
    By Outlaw Torn in forum General
    Last Post: 18-09-2006, 09:09 AM
  2. Two Questions
    By jamo in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-09-2006, 10:21 PM
  3. A Few Questions
    By 4PLAYN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-08-2006, 10:29 PM
  4. 2 questions
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 26-09-2005, 03:54 PM
  5. VY 914 Questions
    By mungx2 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 18-09-2005, 06:24 PM
