Results 1 to 19 of 19
Thread: Vn Irs
    Sep 2005
    Adelaide, South Australia
    Default Vn Irs
    As the topic states, This is about VN Indipendant Rear Suspension.
    At the moment my Berlina has Live Axel and i would like to change it to IRS and have a rear suspension. How would i go about this?
    VN SS and all the HSV VN's i assume had IRS, yet finding one of those in a wrecking yard will be like finding a teeth on a duck.
    Any help is appriciated.
    Adam.
    VN Commodore
    Feb 2006
    as far as i know no vn's came out with irs. i have always wanted to put it on my car.. but i have been told it doesn't bolt up
    xcop5l's Avatar
    xcop5l is offline 4th year spanner spinner
    VN ex cop 5L
    Jun 2006
    ol' geelong vic
    i think vp calais did but im not sure
    Stato on the inside, berlina on the out side,5ltr under the bonnet,stockies all round...........that thing has to be a sleeper
    MY RIDES
    [SIGPIC][/SIGPIC]
    http://forums.justcommodores.com.au/...ad.php?t=41837
    1991_Vn2nV's Avatar
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    IRS was introduced with the VP... not available in ANY VN's.
    Originally came out on the VQ stato and was adapted to the VP from there.
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    1991_Vn2nV's Avatar
    Mar 2006
    Quote Originally Posted by Mack
    Is it possible to make a VN IRS tho?
    Yeah it is.
    But its a lot of hassle and for what gain? And springs, exhausts etc. all begin to cost more and need to be replaced...
    Y-Series Senator Signature
    Jan 2006
    Willall Racing
    JD
    JD is offline Donating Member
    VS Berlina
    Aug 2006
    Deep South, SA
    VP Executive R-spec
    Jan 2005
    It's easy as man, go and buy a rolling VP shell with IRS and swap everything over that's the easiest way you are going to get IRS. But really you don't want it, the VP-VZ IRS is crap anyway, you might gain a bit of traction around corners but there are alot of disadvatages too.
    The only time to get IRS is when it's a good setup like in the Fords or the VE or anything that runs a proper 4 arm setup like that
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    Yeah, Foamie has a point there. I woudn;t bother about the IRS, Live axel all the way!
    1991_Vn2nV's Avatar
    Mar 2006
    253@7k is offline 300rwhp supra. yay.
    TT Supra/HZ Ute.
    Apr 2006
    Quote Originally Posted by 1991_Vn2nV
    So does my Berlina And other VN's
    And my HZ.......
    PaRaDoX's Avatar
    PaRaDoX is offline boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    TT Supra/HZ Ute.
    Apr 2006
    Quote Originally Posted by PaRaDoX616
    Traction.......whats that?
    Something that seems to be easily lost with an 8......
  15. #15
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
  16. #16
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    how can you loose something you never had
    Quote of the century ladies and gentlemen.
    ROFL.
  17. #17
    VN BT1 5 Litre 5 Speed
    May 2006
    Melb
  18. #18
    90 VN SS 5speed, '90 VN Calais 5speed
    Jan 2006
    stanthorpe, qld
    Quote Originally Posted by stocko_VH
    Dont you mean tooth or finding teeth on a duck. (sorry i couldn't resist)
    And paradox that was good
    Adam
  19. #19
    TT Supra/HZ Ute.
    Apr 2006
    Suppose it was it was coming to you but then a quick change caused it to slip away.
