Just found this in another thread can anyone confirm this error code as my manual says nothing of it.
Error Code - "35 Closed throttle idle speed is more than 75 rpm above or
below correct value for more than 45 seconds"
As i thought (no tacho) my car was idling too fast b4, but didnt get an Error 35, and surely i was pulled up at a set of lights for 45sec. Or maybe my TPS isn't registering a fully closed throttle...?
What say ye, yeh or nay to error code 35? lol
Apoc out.
where did you find this error code?
From a thread "Car smells like s*#t"
Posted by PaRaDoX616....
Code 35 is to do with the idle air control valve position.
Clean your throttle body, and the IACV, check the electrical connection to both the TPS and the IACV. If you still pull a code 35 then replace the IACV
Gravity is proof that nature keeps getting us down.
