need help asap wont turn over no click from starter or anything have power speedo dyed just before it wont start![]()
I suppose you've checked the basics? To me it sounds like batt flattery!
have power lights and all just no starter
its like there is no power to the starter
mayeb there isnt enough power to your starter :P, the dash lights are workin u mean? - they will work for a while on a flat batt.
Check your relays and fuses.
cheaked all fuses new battery and all good my be solanoyed?
check the alarm that its turning off?
cant be to solenoid, the click ur supposed to hear is ur solenoid. do u have a multimeter or a testlight?
check your starter remote wire the some times fall of. thats the little wire on the starter
Stato on the inside, berlina on the out side,5ltr under the bonnet,stockies all round...........that thing has to be a sleeper
MY RIDES
[SIGPIC][/SIGPIC]
http://forums.justcommodores.com.au/...ad.php?t=41837
how can i tell if a solenoid is stuffed?
the solenoid is meant to click (engadge/disengadge the starter motor with the flywheel) so its not clicking there could be a electrical issue or the solenoid is stuffed.
ive cheaked all solenoid is getting power so maybe its that
and the remote wire is working? or do u have a relay that could be faulty?
sometimes the contacts on the soleniod get dirty. ya just have to take the end cap off and clean it all up..
have your tried shorting the starter
yip it turns i think its the soleniod
put new starter in no good,all fuses good,ignition good,nutral switch good,relays good,ill fire bomb it soon ha ha ha i bet its something small
Not sure if it helps but on my GF's VR V6 if I remove the fuel pump fuse there is no start, no click, just nothing? Found this out while trying to bleed the fuel pressure from the rail.
how did ya go with ya car. did ya sort it out in the end???
its in between starter relay and the clip just near battery new relay and all just no power out and how do you fix ya speedo if it stops working thanks all
