after a quik search, couldnt find a clear answere. when did vn s2 start? also did the vp use the same gbox as vr? and did vr and did vr use the same gbox as vs? getrag??
I'm pretty sure the Series II started around May?! 1991. I think it was May, I'm not sure bout VP and VR using the same gearbox, But I'm positive they did. And the VS had a different gearbox to the VR.
:: hakhawk :: says:
im a geek by day
:: hakhawk :: says:
a mass/axe murderer by night
:: hakhawk :: says:
and a rabbit sometimesI'm only nice to one person per day. Today is not your day....
Tomorrow doesn't look good either.
God must love stupid people, He made so many.
Originally Posted by 1vngal
VN S2 started in like August/September 1990, VP followed a year later. VP does not use the same gearbox as a VR. VR is computer controlled whereas VN-VP is kickdown cable controlled. VR/VS had the same box, 4L60-E (E for electronic controlled). That's for auto. For manual, VN-VS S1 used a Borg Warner T5 for the 5spd V6, and VS S2 used a 5spd Getrag.
For more info, visit http://www.users.on.net/~%20nweber/commodore/
thanks for clearin that up for me![]()
I thought the 1990 vn was classed as the "series 1.5" Meh, oh well....At least i know i was wrong now!Originally Posted by Nikkojoe
:: hakhawk :: says:
im a geek by day
:: hakhawk :: says:
:: hakhawk :: says:
S1.5?? what difference would there have been with that between 1 and 2?
Nar, my vn is a Feb 1990 and its still a series 1. They were out for a very short time. Im sure it was around March/April when the S1.5 (twin water bottle design).Originally Posted by 1vngal
Basically S1 had the basic fwd buick motor converted to RWD. This ment that the thermostat was at the rear of the engine and had no radiator cap and overflow bottle. However, it did have a surge tank which you fill the water from. There were also various other internal differences.
Series 1.5 had an overflow bottle aswell as the surge tank and some slightly modified internal components, although remained pretty much like the S1
S2 is pretty much the same from VN S2-VR (Thermostat at the front of the engine, revised coil packs, bellmouth in thottlebody elbow, revised fuel rail are just some of the exterior changes). Only minor changes here and there from VNS2 to VR
My mates vn is was made feb '90
