ok ill start with the master cyl question cause its the most important. Ive lost brakes so my car is inoperatable. Now i have a master and booster from a v6 vs in the shed... I know they are diffrent but can i just make it fit??? or not. Ive been told you can and ive been told you cant.. I dont wanna make it fit to find out it wont work.
Ok second question. Are series 1 vn heads the same as series 2.
Ive done a bit of a search on both but im just getting confused.
Michael
- OWA650 -
"Blown Vr wagon, 275hp at the wheels.. Much more to come in the near future!"
from what everyone has said on this forum they are a little different. do a search. somoene put some pics up of s1 and s2 stuff the other week. was quite interesting..
It will but you will have to move the brake lines around so the rear line goes to the front and the 2 front pipes have to go to the back...some vs's have abs so there is a chance that the cylinder you have will have a bung covering one front pipe holes that will have to be removed.The rest should bolt up as the dimensions of the booster studs and pushrod lengths and pedal pivot pin holes are all the same as a pre vs car.
This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain
......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
