Results 1 to 5 of 5
Thread: VN Wagon towbar fitting
    VN Commodore wagon
    Sep 2006
    st. mary's tasmania
    Cool VN Wagon towbar fitting
    g'day,
    can anyone give me any idaea about whethet i have to drop the petrol tank to fit VN wagon towbar
    thanks the spirit
    hakhawk's Avatar
    hakhawk is online now smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    mm, when i took mine off, i only had to drop one of the straps. drivers side one from memory, as it used a bolt in same spot as strap bolt
    SweetWagon's Avatar
    SweetWagon is offline booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    Your in luck, I have recently fitted a towbar to my wagon, if your towbar looks like the one in the attachment then heres how to do it.
    You have to remove the rear drivers side, fuel tank strap bolt, making sure you remove the spacer. This is becase the towbar mounts on this bolt location and you will not need the spacer anymore as the plate will substitute this now. then you have to centrepunch all 5 holes (2 drivers side, 3 passenger) so you can see where to drill on the inside for the bolts (The holes need to be a large as the diameter of the spacers). Once all 5 holes are drilled, lift the towbar up with a mate and from the inside feed the bolt through the mounting plate and make sure you use the spacer which goes in-between the mounting plate and the chassis rail and do the nut up from underneath.
    If you have any probs or need pics let me know
    SweetWagon's Avatar
    Jan 2006
    Springwood NSW
    Commodore 1988 VN Calais S1 V6
    Apr 2010
    Adelaide. South Australia.
    I had a Vn Wagon a few years ago and going by the picture that you added
    It looks very much like the one that I fitted to my wagon.
    I would say you have the right one, good luck.
    cheers.
    Bob...
    bobmat111.
  1. towbar to wagon
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 21-04-2007, 10:39 AM
  2. VY Wagon Towbar
    By VYWORKWAGON in forum VY Holden Commodore (2002 - 2004)
    Last Post: 26-10-2006, 03:06 AM
  3. Help fitting towbar
    By SweetWagon in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-07-2006, 05:21 PM
  4. towbar. wagon and ute
    By bisonlee in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-05-2006, 07:50 PM
  5. VX towbar, will a ute towbar fit a wagon???
    By Phrog in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-01-2006, 03:31 PM
