Register - Members List - Calendar - Mark Forums Read -
Go Back   Just Commodores > Holden Commodore Related > VN - VP Holden Commodore (1988 - 1993)
VN - VP Holden Commodore (1988 - 1993) Talk about anything relating to the VN - VP Holden Commodore.
Reply
LinkBack Thread Tools Display Modes
  #1
Old 13-09-2006, 09:15 PM
michaelw's Avatar
Ride: VX S2
Trade Rating: (0)
michaelw Berlina
Default replacing injectors how?
Hi all,
I have just got a set of new injectors and have skillfully managed to lose my gregories. Can anyone supply me with a link or a step by step guide to removing the old and replacing them? Or fire off a scan of the pages in the gregories?
Mike
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!Google Bookmark this Post!Yahoo Bookmark this Post!Bookmark to AskJeeves!Bookmark to Slashdot!Live Bookmark this Post!Spurl this Post!Reddit! Wong this Post!
Sponsored Links
  #2
Old 14-09-2006, 08:39 AM
Ride: VN Commodore
Trade Rating: (0)
defa Executive
just unbolt the fuel rail and undo the fuel lines.
  #3
Old 14-09-2006, 09:24 AM
Shortstuff's Avatar
Random
Ride: EF Falcon 6 & EA Falcon 6
Trade Rating: (0)
Shortstuff Executive
I'll post up a "how to" in the how to section for you with a few pics put a link here when it's done.
You need the engine to be cold when doing this job, and you will also need to depressurise the fuel system before starting. I followed the steps in the Gregory's manual but still got a bit of a jet of fuel when I removed the first injector, hence the engine needs to be cold!
__________________
Whoever said 'There is no substitute for cubes' had obviously never heard of Jet power
  #4
Old 14-09-2006, 09:31 AM
Mackurbation's Avatar
Cant Pretend
Ride: '92 HSV VP GTS
Mackurbation MonaroMackurbation Monaro
Well lucky for you I did this for the first time about 3 weeks ago. What I done is:
1: Disconnected the battery (Important)
2: Mark the electrical wires so u know which one came off which injector.
3: Disconect the electrical connectors from the injectors
4: unclip the little clips with a small screwdriver or 2 (the clips can be found just under the fuel rail). The clips hold the injectors into the fuel rail.(6 clips in total, try not too bend these if you have to reuse them.)
5: Unbolt the bolts on the metal clips holding the fuel tube that flows fuel from one side of the fuel rail to the other fuel rail.
6: Skillfully remove the unbolted fuel tube without bending it, if you cannot manage to do it this way, the easier option is to unbolt your alternator which will be in your road. (Be prepaired for fuel to spert out because of the pressure, it will stop after it depressurises.)
7: Now unbolt the fuel rails from the plenum (the engine) and then pull gently the ruel rails off the injectors, it may seem like its not coming off, but it will.
8: remove the injectors from the plenum and there you have it, old injectors are out!
9: Clean the holes in the plemun where the old injectors come out of so when you put the new ones in you have a good seal.
10: Do the upove steps in reverse to put it all back together again!
Hope that Helps!
__________________
Build 018/130
14.6 Sec Sex Machine
If its got WHEELS or TITS it'll give you the Sheets!
Ban LOW Performance Drivers, NOT High Performance Cars.
  #5
Old 14-09-2006, 12:02 PM
Shortstuff's Avatar
Random
Trade Rating: (0)
Just did a big how to but it doesn't seem to have appeared!!
__________________
  #6
Old 14-09-2006, 12:10 PM
AirStrike's Avatar
<---------It's coming!
Ride: 91' VN SS & 94' VR BT1
Trade Rating: (0)
AirStrike Off the chartsAirStrike Off the chartsAirStrike Off the charts
Its there now. How-tos have to have mod/admin approval.
AirStrike
__________________
function > form
  #7
Old 14-09-2006, 12:15 PM
Shortstuff's Avatar
Random
Trade Rating: (0)
Ah, OK. Thanks for that
Here's a link to it!
VN Injector Replacement guide
__________________
  #8
Old 14-09-2006, 01:02 PM
Cant Pretend
Great Guide mate!
__________________
Build 018/130
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Thread Thread Starter Forum Replies Last Post
vl injectors vr_owner VL Holden Commodore (1986 - 1988) 5 08-10-2007 01:50 PM
Injectors YByN8 VT - VX Holden Commodore (1997 - 2002) 4 22-03-2007 09:53 PM
injectors dave.b VL Holden Commodore (1986 - 1988) 0 24-09-2006 08:43 AM
Injectors vsII manual VR - VS Holden Commodore (1993 - 1997) 7 25-01-2006 03:25 PM
injectors?? KLR38L VR - VS Holden Commodore (1993 - 1997) 2 18-01-2006 04:26 PM
Online Loans | Job Listing | Credit Counseling | Loans | Debt Consolidation | Car Reviews
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
