hi, ive nearly finished my crs kit but i need help.
basicly im upto adding a bov (waiting 4 it to come back from being welded)
then ive got to add the pully and belt.
is it nececary to relocate the pcv to the inlet of the blower?
how have other people added there pcv hose to their blower intake?
is there an adapter i can use to mount the hose to the inlet blower pipe?
thanks heaps
wen my bov comes back i will get a belt and mount the extra tension pully
and be finished. but i need to work out how to attach the pcv first.
can you be more specific. got any pics . i have a crs kit so if you can tell me exactly what part your looking at making then i will have a look at what crs used for ya...
only good cops a dead cop...
s1 vn commodore turbo
t3/t4 front mounted turbo
Intercooler ---3"exhaust
stage 2 shift kit---B&M Qicksilver shifter
3:45 lsd
18" Cv8z Monaro rims 245's
basically i need to work out how i can connect the pcv hose to
the blower inlet pipe.
thanks
i belive it is nessacery to run the pcv into some where either the intake or a catch can, they usually use those on turbo setups.just run a hose where you want it to go.
if you leave it the way it is you will pressurise the crank case and sump ect and it is possible to blow out seals but you will more likely have alot of oil leaks
Stato on the inside, berlina on the out side,5ltr under the bonnet,stockies all round...........that thing has to be a sleeper
MY RIDES
[SIGPIC][/SIGPIC]
http://forums.justcommodores.com.au/...ad.php?t=41837
my main question is how i can connect the pcv hose to my intake pipe?
is there some sort of adapter i can get?
thanks for the replyz
drill a hole in the intake pipe
get a threaded hose plug thing attachment
put thread through pipe, do up nut on the other side (with some kinda seal in between)... presto!
yeah thats exactly what i need but where can i find one?
cheers
has anyone else ever experienced a intake restriction?
only sometimes i get to about 4000rpm in gear at wot and it goes down from 0psi (turned off) to -15 psi, where it should be at 0psi And virtually stops reving just sitting on 4500rpm.
is this definetly a intake restriction or could it be an exhaust restriction
or worse a motor problem?
sounds like the intake has a blockage
go rite over your intake pipes and inside and have a look
ill bet its that f****** pod filter colapsing and blocking up your intake,take it off and take it for a drive or just rev it up and watch your pod
you can get those fittings from bunnings
MY RIDES
[SIGPIC][/SIGPIC]
it wouldn't suprize me if it was the pod.
it only does it sometimes and i havent heard of any major power
losses due to the sc14 clutch not on.
might have to go fit the original top of the cai and the k&n panel again to test.
cheers for the reply,
hope the filter fixes this.
did taking off the pod fix the problem???
MY RIDES
[SIGPIC][/SIGPIC]
i pulled off the pod and went for a spin,
still no go, it wouldnt go past 4500rpm.
pulled of the sc14 inlet manifold and it was alot better,
but still not perfect because the blower was restricting it slightly,
but it still went to 5500rpm.
the reason was because the blower inlet was touching the hood,
and was choking/squashing the silicon pipe coming off the top of the charger.
pic:
