Hey all... Last night on my lil bit of a drive I noticed some really weird things.....
On full lock my steering was like it had a spool = ?Diff on its way out?
Hard Punch in 2nd = ?Engine Light?
Weird !CLUNK! noise in back left of car = ?NO IDEA?
Apart from that she's beautiful...
Any help appreciated
MaT
Originally Posted by garth
Ok.....
Cruise control is also dead, Checked connections & fuses, there all fine.........
MaT
Perhaps you have damaged the axle on the back left hand side?On full lock my steering was like it had a spool = ?Diff on its way out?
Although the had punch in second... is that only when its cold or not? Definitely sounds like its something to do with the diff.
i wonder if youre having the same rear clunking noises as my car
1995 Manual HSV Clubsport
1991 Supercharged VN Berlina
Rear clunk noise may be bushes or perhaps one of your exhaust brackets ?
Is it only under load or when you are turning or is it a constant thing ?
Have you done a fault code test yet matt?
AirStrike![]()
Selling FG G6E Turbo and buying a N/A Supra
No fault codes come up........ She's clean....
Clunk comes from back left when i put foot on accelerator...
I'll see how she is later on, I found some coins, that'll fill my gas tank up, goin to go see a friend tonight, an go cruising... See if anything happens again...
Just the 2nd gear engine light..... Not worrying me just a bit of a head ****...
No idea if she leans out around 3800-4800rpm or what... That could be a possibility though. But only 2nd gear... Does it on petrol & gas.
MaT
If the check engine light is coming on but no code listed it means its an indeterminate problem. Easiest way to check is to take it to someone who has a Tech 1 controller and get them to plug it in and go for a drive. If it happens again it will show up on the controller.Originally Posted by HoZy
AirStrike![]()
if its got factory cruise check your brake lights the cruise operates on that
Stato on the inside, berlina on the out side,5ltr under the bonnet,stockies all round...........that thing has to be a sleeper
MY RIDES
[SIGPIC][/SIGPIC]
http://forums.justcommodores.com.au/...ad.php?t=41837
ive got a rear clunk sometimes it happends on a rolling start. Think its the diff, could be the tranny though.![]()
Left side clunk under load may be the bushes or panhard rod, I had a similiar clunk from the rear of the wagon and changed upper and lower trailing arm bushes and clunk has now gone
minispool time hozy????
mine makes the clunking noise aswell but its only say if i drop it into reverse on a cold morning, dosnt happen often
i have similar problems with my vn v6 5speed
i have a bit of a clunk (diff?)when i on/off the throttle,
and wen i nail it off the line it makes a noise that sounds like bearings or
grinding or something.
does anyone know what this is and how to fix it?
cheers
The clunk is probably the backlash in the diff. Both my LSD and open diff are quite loud dropping the clutch and on and off the throttle (I notice it beacause I don't have a stereo). I've never been worried about it, I give it heaps and both the diffs are still holding up. I'm in the process of tightening up the LSD though. Just have to get the right thickness of shims so it's just off being a lockerOriginally Posted by ashzv6
and not so much backlash. Is your diff an LSD? Because LSDs do make quite a bit of noise at times, especially if you're nailing it, like the clutches slipping and stuff.
Hozy did you mean one wheel was skipping at full lock? You have an LSD right?
you have a bent axle my friend
never late in a 3 0 .. uhhh ... intercooled turbo
yes i drive an mx6 turbo ... its probably quicker than yours.
bent axle i reacon and it was prob from when you had your spool
[SIGPIC][/SIGPIC]
Mat had a spool at once?
My nephew had this crack sound from the left side not always but sounded like metal cracking with a glass crack also. He done the diff, It only did it turning one way. They had the whole rear looked at to be sure and found the diff was gone.
Many mechanics will look over a car if they have the time for nothing and tell you whats wrong and how much. I's how i found a crack in the tailshaft.
Originally Posted by Yoda
Im Pritty shore he didOriginally Posted by tr3nt
didn't you matty
[SIGPIC][/SIGPIC]
SHHHHHHHHHHHH!Originally Posted by Benji
Well car was puring like a kitten last night and today, no skipping so i turnd some tight circles tonight.....*shiftey eyes* No skipping... No engine light in 2nd gear...... No clunk........
She's runnig sexy! and loving it.
MaT
