gday i was wondering if anyone new how much a new clutch costed? and how much to be put in?
I think mines on the way out, when i 1st start it and take off it sometimes jumps and feels like it slips then suddenly grabs and slips again and does this about 3times per second so its a realy rough take off and it sometimes looks like i dont know how to drive haha. But when it warms up a bit it starts coming good again. Oh and on hillstarts it does it. Would this mean the clutch is on its way out? Or what would be causeing this? anyway to adjust this? cheers.
Australia. Love it or leave it
As long as your clutch pedal is about level with the brake pedal theres not much to adjust.If you use a repco clutch/pressure plate kit you are looking at 300-350 retail or less of course for trade.Add 30 to machine your flywheel and probably 200-300 for labour to fit it.
This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain
......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
get an extreme clutch from adelaide clutches. they sometimes do an exchange if they can use your old clutch. they are very good to deal with. i have bought a couple off them. i got a ceramic clutch for my pulsar. it is a good street clutch. they are really soft on take off. and i have never had mine slip..
How much are they worth?
i got a new clutch for my 5 speed fitted by a backyard mechanic in canberra for $450
300 - 350 for a HD clutch... around 250 for standard.
80 for machineing of flywheel and then 3-4 hours work (ripping out tranny etc) at 60 an hour, 240ish to have in. Not cheap to do!
aZk.
i forget how much my clutch cost. but most of the cost was the pressure place. the clutch plate itself was pretty cheap.. i did find the reciept the other day but i don't knwo where i put it.. it was a few years ago when i bought my ceramin one.. what ever you get. make sure it has springs in it. don't go getting a solid button clutch. if i was you i would ring adelaide clutches and tell them what you want and what you have and they will give you a bit of advice..
I paid $220 for a thurst bearing_clutch+pressure plate with v8 diaphram (for my v6) all brand new, plus 15 bux delivery to my door....
fitted myself in one night.
looking at around 300 labour at a mechanic i'd say.
really ya don't need a heavy duty pressure plate.. depends how ya drive really. if ya just putt around there is now point. i know when i bought a new clutch for my rodeo i was going to get a heavy duty pressure plate but they cost a shitload for deisel rodeo's. so i got the standard one which is supose to be 20% heavier. i tow a lot of wood and hay with my ute. sometimes around 4 tonne's with the trailer on the back. and it hasn't slipped once. so ya really gotta think of what ya want.. i have a heavy duty clutch in my VN and it is pretty stiff. my girlfriends hates it. so she doesn't drive it, which works out good.. hahaha
Where is a good place to go in SA to get them. I would like to know a reccomended place to buy them as i burnt mine away quite well. JSTPOZN rekons that the clutch cable is gone and isnt connected. I hope to pull the box off in the next week or so (weather and work permitting) and have a good look at the situation. I would like a HD clutch as i will be towing trailers with cars occasionally and also hauling rather large loads inside and in the trailer on occasions. Anyone with idea of what i would need. for the usage that i will use next year when i get my p's ... should i go standard or HD?
Cheers in advance.
Adam![]()
i would go HD if ya are going to do any towing. ya may not need it but it will be better than realising ya need it after.. look up adelaide clutches. get a quote off them. i am pretty sure they should be cheaper.. ring repco or some other place after that for a second quote to make sure..
