little wire on starter is dose that have power going through it when ignition is on,mine has no power all fuses good,all relays good,nutral switch good,ingnition is good to.??????????????????????????????????????????????? ?????????????????????????????????????????????????? ?????????????????????????????????????????????????? ?????????????????????????????????????????????????? ??????????????????????????![]()
earth .....
never late in a 3 0 .. uhhh ... intercooled turbo
yes i drive an mx6 turbo ... its probably quicker than yours.
it will only have power there when cranking not when ignition on
Stato on the inside, berlina on the out side,5ltr under the bonnet,stockies all round...........that thing has to be a sleeper
MY RIDES
[SIGPIC][/SIGPIC]
http://forums.justcommodores.com.au/...ad.php?t=41837
im out of ideas then dose everything but turn over fuel pump turns on,relays work,neutral switch works,fuses good,ingnition good gets all power.may be ill just get new computer thats the only thing i havent tryed and am about to light it on fire 2 weeks of hell.it will be a little thing i bet my speedo stopped right before too if that helps.
i dont know what the problem is.. but one of mates had a weird way of finding out what the wires where for.... he used to make sure all the fuses were alright then he used 2 strip the wire and touch the earth.... and then he would check the fuses and wich one was blown he would change it and work his way from there..... i dont recomend you do this but this just reminded me that he used to do it because he used 2 find alot of wires that didnt know where they went(the result of the guy who owned it before hand playing with the electricals to much) hahahaha
a earth leakage will make u think its everything but the real issue,
i changed my starter motor over and accidently short circuited it, you'd crank it and it'd blow the circit breaker, wouldnt even crank.............make sure the terminal isnt touching anything metal except what its ment to be (the big fat terminal)
