Results 1 to 6 of 6
Thread: brakes question
    vn wgn
    Apr 2004
    western subz melb
    Default brakes question
    hey all i want to know hwat is the diff betwwen v66 and v8 brakes asi want to up grade my brakes in mt car ( but as cheap as possible
    VN 5 spd/VR Calais daily driver
    Mar 2006
    NZ
    Most V6s don't have FE2 suspension which came with 290mm disks. Most V8s had this. You've probably got 270mm disks. As far as I'm aware the calipers just bolt straight on (same size pads too) and just get a pair of slotted 290mm disks for some extra bite. It's a lot cheaper than a VT break upgrade. I think you can get a pair of VS or VR (not exactly sure) calipers with have cooling fins if you're doing a bit of heavy breaking. Run some quality break pads too. Does anyone know if it's worth while upgrading to a 1" master cylinder?
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    the 1" master cylinder is a worthwhile upgrade it should give a slightly firmer pedal and a little less pedal travel as well. you should be able to get one from repco that'll bolt straight on from the V8 model
    Body by Holden, Soul by Brock
    the Legend will live forever
    savage1987's Avatar
    savage1987 is offline fail champion
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Question
    Quote Originally Posted by VN Commy
    you can get a pair of VS or VR (not exactly sure) calipers which have cooling fins if you're doing a bit of heavy braking.
    Anyone painted those calipers? We're painting the hubs on my mate's VR - bright yellow, to match the rest of the car and we're looking to do the calipers too. Is there any way to do this without disconnecting any lines, or do we need to sand the calipers back to bare metal etc . . . ?
    Apr 2006
    Auckland NZ
    VHT do a line for high temp areas etc including brake calipers/rotors i believe, especially formulated to withstand brake fluids etc. give em a good clean with some degreaser first and a scrub with a wire brush to remove any shite should do. i'd suggest unbolting the caliper, remove the brake pads, get some news paper and cover the brake rotor with the news paper and then sit the caliper on that to paint it, wrap something aroundthe brakelines to keep that paint free also
    HATER VP Guest
    What model are you talking about? VN / VP Brakes had different calipers, they had fins in them. They are the same caliper as used in all VR Models. Also different master and Booster.
    Ive got VT Calipers, DBA Slotted Rotors for VT on my VP V8. Well worth the upgrade.
  1. VL Brakes
    By mitch1234 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 30-12-2007, 09:36 AM
  2. brakes
    By Aryashahin in forum VY Holden Commodore (2002 - 2004)
    Last Post: 29-09-2006, 01:03 AM
  3. HSV brakes question
    By EXCESSV in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-09-2006, 07:15 PM
  4. New Brakes Required.. Question
    By Swift Jimmy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-10-2005, 01:08 AM
