Results 1 to 14 of 14
Thread: misfire?
    91 VP com
    Jul 2006
    Exclamation misfire?
    ok so when i take of from 5km/h or under with my foot to the floor the car just rolls along and sorta sounds like its missing and putts n sputters for about 5 seconds then it picks up revs a bit n then goes like normal..... and some times if i doing between 30 -60k's and drop it in to 2 it goes like a cut cat n just luanches and other times(in the same conditions) it'll just rev up a bit n slowly accelerate ...not sure why this is or if the 2 problemsare related.
    I don't know much bout these cars but i think it maybe coil packs, spark plugs or leads, any one with any ideas, i don't wanna fork out on a bunch of parts i dont need.
    cheers Steve
    busted ass vp
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    Hmm, yea. When was the last time you changed the leads and sparkplugs, atleast take the plugs out and have a look how dirty they are.
    xcop5l's Avatar
    xcop5l is offline 4th year spanner spinner
    VN ex cop 5L
    Jun 2006
    ol' geelong vic
    sounds to me like a fuel problem, a blockage or dodgy fuel pump or drity injetors
    Stato on the inside, berlina on the out side,5ltr under the bonnet,stockies all round...........that thing has to be a sleeper
    MY RIDES
    [SIGPIC][/SIGPIC]
    http://forums.justcommodores.com.au/...ad.php?t=41837
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    fuel filter, cheap, easy and if you haven't done it recently it'll definitly need doing
    Body by Holden, Soul by Brock
    the Legend will live forever
    JD
    JD is offline Donating Member
    VS Berlina
    Aug 2006
    Deep South, SA
    ok i had a similar problem 2day had my vn idling and it would almost conk out then go back up to normal rpm it would it every minute or so.
    turned out to be negitive connection to the battery was almost off!
    We got rep back, yaaay!
    91 VP com
    Jul 2006
    Thanks for the replies guys i guess i'll have to check out a few things.... next weekend i planned to get new leads n plugs, while i'm at the shop i might get a new fuel filter.... check the battery terminal too.... if no luck i'll try the injector clean if that stuff is any good?
    busted ass vp
    92 VP Exec Wagon
    Mar 2006
    Default coil pack
    Quote Originally Posted by 10000_fists
    hey mate im Kuzzy,with the problem u have or had also check your coil pack the do seem to go at some time i even had to repair mine they are a pretty big job
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    Yeah, injector cleaner is good, good to do on a regular baisis too! Get some Nulon Fuel injector cleaner (red in colour) and get a full tank of premium petrol. Fuel injector cleaner is susposed to treat 2 tanks, but put the whole bottle in with 1 tank, works beter that way. It wont hurt anything, ive even put 1 Litre of metho, $20 premium fuel , a bottle of fuel injector cleaner and a bottle of Nulon octane booster in at once and she ran goooood!
    91 VP com
    Jul 2006
    Quote Originally Posted by Kuzzy
    Thanks kuzzy...when i check th coil packs when shoud i look out for or do to test they are ok? i thought that it woundn't be very hard to change over coil packs?
    busted ass vp
    VNV6VENGEANCE's Avatar
    VNV6VENGEANCE is offline VeNgeance
    VN Turbo
    Jan 2006
    adelaide,sa
    its not i don't know what he's talking about. maybe he meant repairing a coil or dfi module. switching the coil is as easy as unscrwing the 6 torx screws on the pack and switching the new coils with the old..
    only good cops a dead cop...
    s1 vn commodore turbo
    t3/t4 front mounted turbo
    Intercooler ---3"exhaust
    stage 2 shift kit---B&M Qicksilver shifter
    3:45 lsd
    18" Cv8z Monaro rims 245's
    91 VP com
    Jul 2006
    thanks VeNgeance that all i thought there was to it. is there much worth in installing an msd(ort similar) coil pack?
    busted ass vp
    VN Turbo
    Jan 2006
    adelaide,sa
    yeah well when you add it up for the long run there is a big advantage with msd. Obviously better ignition timing, but they got 3 coils inside each pack( if one f#cks up there are two left in each pack for backup) There about $75 for one. $75x 3 = $225. One genuine holden coild pack costs $100 so if you have to buy 3 thats $300. msd saves you $75 and works better.
    3:45 lsd
    91 VP com
    Jul 2006
    thanks...where should i buy from bursons or repco? somewhere like that? what should i ask for, is there a few different MSD ones for the vp 6?
    busted ass vp
    vnexecutive wagon
    Mar 2006
    do a diognostic check you know bridge ato be turn on key count the flashes if it does come up 12 try plugs use ngk you wont have a problem
  1. engine misfire
    By half in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-11-2007, 02:56 PM
  2. misfire
    By immortality in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-10-2007, 11:08 AM
  3. vt misfire
    By linc in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-06-2005, 11:57 AM
  4. Misfire: likely causes?
    By vn2nv in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-08-2004, 11:37 PM
  5. Vs Vr Misfire At Idle
    By stheggie in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-01-2004, 07:15 AM
