Page 1 of 2 12 LastLast
Results 1 to 25 of 28
Thread: Catalytic converter fell apart internally - it rattles!
    savage1987's Avatar
    savage1987 is offline fail champion
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Unhappy Catalytic converter fell apart internally - it rattles!
    I was laughing at Cogez's VP Calais the other day because when you rev it to about 3000rpm, hold it, then let go, you get an odd-sounding rattle from the catalytic converter. Sounds horrible.
    The other day I realised, to my embarrassment, that my VN has the same problem! It's just harder to hear mine because I have a 2.5" with just one muffler, no resonator, while he's got a pretty standard system on his.
    I've been quoted $270 for instal of a new converter, or $100 for a second hand one . . . is this reasonable? Considering the fact that I'll be getting Pacemaker extractors in the future (possibly soon) should I get a different type or size? I've heard the ones from the VT/VX commodores flow really well - would it be simple enough to fit one of those instead?
    Cheers guys
    Sam
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    We picked up a second-hand one ($100) for Cogez's VP today. Bolted it up but having the same rattle problem. Do ALL VN/VPs have this problem?? What else could be causing this rattle? Something in the engine itself that just SOUNDS like it's coming from the exhaust??
    Or is it probably just because the second-hand one was just as rooted as the original one??
    PS The 3800 block has a wicked crackle if you run it with the exhaust unbolted at the end of the headers (couldn't resist :P)
    90 VN SS 5speed, '90 VN Calais 5speed
    Jan 2006
    stanthorpe, qld
    well i took my exhaust off and i found that my muffler was full of rust.
    it could be that rattling and not the cat
    Adam
    Morton's Avatar
    Fairstar the Funship
    May 2006
    I have a good vn/p cat sitting in the garage. Shame you live in Canberra. You should be able to pick one up from a good wrecker for $50-60.
    The 1972 HQ Kingswood
    VP Executive R-spec
    Jan 2005
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    But a second-hand one from a VP or whatever will be just as old = worn as the current one . . .
    The rusted muffler issue - maybe on Cogez's, but my system is less than 12 months old from the cat back.
    hmmm . . .
    xcop5l's Avatar
    xcop5l is offline 4th year spanner spinner
    VN ex cop 5L
    Jun 2006
    ol' geelong vic
    before you put the cat on give it a shake if it rattels dont use it
    go over your mufflers and give them a bash with your fist if there rooted they will rattel
    Stato on the inside, berlina on the out side,5ltr under the bonnet,stockies all round...........that thing has to be a sleeper
    MY RIDES
    [SIGPIC][/SIGPIC]
    http://forums.justcommodores.com.au/...ad.php?t=41837
    VP Executive R-spec
    Jan 2005
    Quote Originally Posted by savage1987
    hmmm . . .
    A dead one can be empty inside! ie noooooothing in it.
    If you hold the cat up to the light you can see right though, if it looks all kinda tripy but all even like a flies eyesight then its ok , you can get rattles in the cover of them with out the wires inside being broken
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Neither one rattled when shook. I'll give the mufflers a bash and see what happens. Doesn't explain my rattle though . . . maybe mine's a cat and his is a muffler
    Shortstuff's Avatar
    Shortstuff is offline Random
    1995 VR II V6 Wagon
    May 2006
    My tailpipe trim rattles at low revs. It drives me mad - sounds like the exhaust is rubbing on the underside of the car.
    Whoever said 'There is no substitute for cubes' had obviously never heard of Jet power
    anton1o's Avatar
    anton1o is offline [GMHVN6]
    VN 6 Berlina '90
    Jan 2005
    West Subs,Melbourne
    Ive got a gay rattle 2, i fixed it by shoving a nice chunk of rubber right at the end where it holds the exaust/tip up..
    Altho that doesnt seem to be doing the job for too long as im rattling again! 2.5" Exaust here i come
    ride; [GMHVN6] Project Streeter - VN Berlina '90 mods; 65mm throttle-body / Cold Air Intake / 8mm Ignition Leads / Exhaust
    future; Extractors , Cam currently; 101.2rwkw mission; 110rwkw
    mouce's Avatar
    mouce is offline Physics Geek
    VN V6 Series 1 Executive Sedan
    Jul 2005
    Sometimes when the cat collapses internally, little chunks of the honeycomb can end up in the pipes. I had to take my entire system off to empty out the bits and pieces when my cat got blown apart.
    Gravity is proof that nature keeps getting us down.
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    'little chunks of the honeycomb can end up in the pipes' . . . oh dear. might give cleaning them out a go, although I'd imagine I need a hoist for that one . . . hmm.
    Jan 2006
    stanthorpe, qld
    a hoist would help.
    but i just put my catback exhaust on with only one side up on ramps. so it would be easier taking one off
    Adam
  15. #15
    VB\VL Crewman
    Sep 2006
    How'd you manage to blow ur cat up? I stuffed mine by launching an exhaust turbine off a turbo thru it!, but yeah, not fun finding the bits and peices in the pipework. If your lucky, u'll probly find the pipe is sectionalised, so u can take one bit off and shake it out, and put another on and so on and so forth.
  16. #16
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    I think mine's just falling apart from age and a bit of hard work . . . either way, I'll have a 2.5" one put on with my extractors later on. I'm just trying to figure out why Cogez's car has a rattle . . .
  17. #17
    mouce's Avatar
    Jul 2005
    I replaced the front muffler section of pipe and I had nothing more than 1 standard VN commodore jack and one axle stand. It took me an entire afternoon to do it, but you can drop it off and bolt it back up with only the rear passengers wheel lifted.
  18. #18
    anton1o's Avatar
    VN 6 Berlina '90
    Jan 2005
    West Subs,Melbourne
    Anybody know of good Cats for vn's?
    Ive heard the VY SS Cat's are good enough for a VN6 with even more then moderate mods
  19. #19
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
  20. #20
    1993 Series II VP Calais
    Sep 2006
    With regards to rattling exhaust problem, I replaced my cat, then all the exhaust from the catalytic converter back, and it STILL rattles.
    **** knows what's wrong with it, I may jump out my window.
  21. #21
    Not_An_Abba_Fan's Avatar
    Not_An_Abba_Fan is online now Exhaust Guru
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Check all the bolts holding your extractors, if they come loose it will sound like a rattling cat.
    Is it an auto? Check the torque converter bolts where it bolts to the flywheel.
  22. #22
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Damn. I just learned to ignore mine. Btw Cogez, if you come over with ur car for Christmas I've found someone who can get Pacemakers at trade price for us. $450 supply only. not bad, hey?
    Torque converter.. ours are both auto, surely after the punishment mine's taken it'd be blown by now if those bolts were loose!
  23. #23
    Zuicider is offline Banned
    Set of thongs
    Caribbean Stud Poker Champion!
    Dec 2005
    Stonedville
    hehe i had the same problem, rattling coming from the cat and mega loss of power, ended up being a shot muffler
  24. #24
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    i got no power loss that i've noticed. having said that, my engine's making so many top end noises that i don't know what's normal any more.
  25. #25
    S Pack's Avatar
    S Pack is offline Topped out @ 230kph
    Mercedes E-Class 2007, E220 CDI Wagon
    Jul 2005
    Germany, Europe
    i put a 3" high flow cat in mine.......fixed my rattle as my old one was rooted and improved exhaust note. Also stopped weird smells from using premium fuels.
    Once a Mercedes is up to cruising speed it lopes along easily and is happy sitting on 180+ km/h all day. Please check the speed limits in your area before attempting this…
  1. catalytic converter
    By StatOmaN in forum General
    Last Post: 10-02-2010, 10:59 PM
  2. catalytic converter - Newbie question
    By BodgyVR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-11-2006, 07:37 AM
  3. Ticking noise, apparently coming from catalytic converter?
    By Famine in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-09-2006, 02:10 PM
  4. VX S S/C6 Catalytic Converter
    By MoSkA in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-04-2006, 07:35 PM
  5. P plate fell off, Need advice
    By flat6 in forum The Pub
    Last Post: 29-03-2006, 07:47 PM
