I want to diagnose a problem i have with my VN V6 Manual.
When driving normally and change into a higher gear the engine revs up then it seems to grab and speed up.
Thats the first problem, which lead into this problem,
When i was driving normally, i changed into 5th and it revved (as mentioned before) but it didnt stop, changed back into 4th, same thing, it seems as if i have lost the clutch+acceleration to the wheels.
Speeking to two of my mates we have come upto these conclusions, its either of these
Clutch is rooted and needs replacing
Clutch cable is streched or needs adjusting
Gearbox teeth are all worn down
The spring has come loose or snapped from the end of the clutch cable
Can someone tell me what has gone wrong or tell me what symptoms or each of the 4 cases above would do?
Adam![]()
you ****ed it You re-build it .... ALONE
Tell the story fully ...
otherwise they will get the wrong impression...
plus it was slipping before then aswell..
Not to mention the fact that its a heavy duty clutch...
If Your In S.A (Adelaide) And Have VR/S Parts & VL Parts For Sale
Go Here ---> http://forums.justcommodores.com.au/...tml#post683835
I have got 4 people saying its the clutch and clutch cable. Anyone else with an answer to this problem? or is it going to cost me a great deal of cash for a new or recon box ??
Could it be any of the above or the Welded diff that came with the car had snapped the last axle?
Before it went i did a 10-15 second snakey in second. didnt clutch it after inital take off .... after the snakey i went about 500 meters down the road to the intersection STOPPED, took off and geared up to 4th, when it went into 5th it didnt go anymore .... the usual slipping happened in the first 4 gears aswell.
What else would anyone like to know?
sounds like ur diff man do u get first second and trird or u got a box full of nuetrauls
full box of neutrals ...
its definatly not his clutch i know that... my guess was his inside teeth after it ****ed up in 5th and grinded them out
i used to have a stock clutch in my nv v6.
mine only slipt when i heated it up, droping clutch with brakes on.
it would take 2 seconds to start to spin the wheels.
now i have a heavy duty clutch.
unsure on brand but it never slips, not even under brutal conditions.
ill take a random guess that it's ur air box thats ****ed and whats happening i it's blowing cold air on to the gearbox which wont heat up and work
BAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAH sorry im bored
[SIGPIC][/SIGPIC]
Ride: DEFECTED VL BERLINA SERIES 2
you lier!
ok sorry
ILLEGALLY SOLD DOUBLE DEFECTED VL BERLINA THATS STILL IN MY NAME THAT SOMEONE ELSE OWNS NOW lol
[SIGPIC][/SIGPIC]
but yeh mate it's ur airbox just bog it up and she'll be right
[SIGPIC][/SIGPIC]
i would like to see you put that in there ... *sarcastic msn smiley*
Ill put it there.....
Who buys illegal defected cars these days
people who want parts from them or to get off defect ...
Definate diff replacement?
Definate clutch cable adjust?
definate VN replacement
definate associate's replacement
[SIGPIC][/SIGPIC]
we gonna need a truck load of bog for adams vn few ton should do it good
maybe if we make a huge bog block we can carve him a new car LOL
[SIGPIC][/SIGPIC]
haha shot gun designin the rims ill just stick hub caps on and call them uniqie zenettie heirs
lol we can get some marshmallows and say they are bumpstops
[SIGPIC][/SIGPIC]
Comon its not that bad ... jesus give the car some slack ...
A few minor things and it should be legal and roadworthy again ....
Cut some slack.
hmmmm maybe we can use slinkys as springs and paper marche the guards since they been cut lool
[SIGPIC][/SIGPIC]
hahah his paper marche car is better then yours :P
sounds like buggered clutch to me
put it in 5th with the handbrake on, then go to take off and if it doesn't wanna stall instantly you're up for a clutch
Luke, i take off in any gear and it dont take off ... a mate of mine who was with me at the time said try getting into 2nd with no clutch .... didnt grind or anything so there must be something stopping the revs of the engine from meeting the gearbox. Meaning that the clutch has gone, and it wouldnt put it past me that the diff has gone too...
