Results 1 to 11 of 11
Thread: VN Bonnet Cable Snaped
    VN BT1 5 Litre 5 Speed
    May 2006
    Melb
    Default VN Bonnet Cable Snaped
    Hey guys,
    Yesterday i went to pull the bonnet cable and snaped it some how, now what im wondering is how do i get the bloody thing open now the cable has snaped?
    cheers scott
    May 2006
    Melb
    Morton's Avatar
    Fairstar the Funship
    May 2006
    There's a couple of threads on this. I think if you can get the grille off, you can activate the latch manually with a screwdriver. Is it snapped at the lever end, or the bonnet end? If it's just broken out of your lever, you can probably grab the cable with a set of plyers and tug while someone holds the front of the bonnet down. Chances are the cable hasn't actually broken, and has just come loose at one end.
    I should really read up on this in more detail, 'cause my cable's about a foot longer than stock. I figure it's got about a month left in it.
    The 1972 HQ Kingswood
    May 2006
    Melb
    cohn's Avatar
    cohn is offline VN28CN
    VN Calais Turbo
    Nov 2004
    Penrith
    is the cable actally snapped? is the lever totally loose and floppy or it just won't release the bonnet?
    if it feels like theres something there still, try getting someone to apply pressure on the front of the bonnet as you pull on the release.
    if its snapped, and if your willing to sacrifice your front grill you can pull it out, its got three screw at the top and three plastic legs which go into the bar, you will be able to get to the latch part. when you remove the grill, looking upwards through the hole,there will be a hole in the centre of the strengthener/ where the bonnet locks to, you should be able to get a flat blade screw driver in there and unscrew the latch part that sits on the bonnet itself, it will taak a bit of effort to undo because there is a lock nut which sits close to the bonnet which you won't be able to undo first.
    another option would be to take it to a smash repairers and see if they got any ideas.
    Soon to be back on the road, Turbo VG.
    VN Executive V6
    Sep 2006
    Liverpool, Sydney
    this isl ike my bonnet, to open her up, its a tow man shop, sumone has to push the bonnet down, and the other person keeps pulling the handle to open it from the driver side. liek the cable is stretched on mine
    Al3x
    Mines just faster cos its Red
    May 2006
    Melb
    nar is deffently snaped coz its dangelling down near the kick pannle so yer, and i got the grill out with out snapping the leg things wich was a bonus dont ask me how i dont it coz i have no idea lol
    but thanx for you help guys
    JSTPOZN's Avatar
    JSTPOZN is offline S.A. The Defect State
    Air Bagged VR Calais, VLCT RB20, VLCT EFI V8 Turbo
    Dec 2005
    SA, North
    Quote Originally Posted by plAythiNG
    Same here
    If Your In S.A (Adelaide) And Have VR/S Parts & VL Parts For Sale
    Go Here --->
    http://forums.justcommodores.com.au/...tml#post683835
    PaRaDoX's Avatar
    PaRaDoX is offline boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    Quote Originally Posted by VN-SV-89-LE
    where bouts in melb are ya man???
    i had the same thing happen to me, i could help ya get it open
    u should beable to remove the screws on the grill from under the bumper for the legs
    and just remove the screws on the top with a thin screwdriver
    from there u gotta jack the latch, its complicated and a genuine pain in the ass
    91 lexcen vn S2
    Nov 2005
    heathmont
    i had to push down on mine a few times when it wouldnt get open...but now it works perfectly....
    anyone got an explanation for that coz i sure dont...lol
    when this happened to a friend of mine he unlatched it using a method kind of the same as the ones u guys are saying...ill try and find out what he did.
    YOU KNOW WHAT THEY SAY.......WAIT......NO I DONT
    VY SS
    May 2005
    SA
    Job is so much easier with a torch, you can see the latch that you have to push towards the drivers side of the car.. Takes seconds..
    Cheers, Gaz
  1. Bonnet release cable snapped how do i open the bonnet
    By S-Pac_Sam in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-04-2010, 09:07 PM
  2. bonnet cable issue
    By Goon in forum VL Holden Commodore (1986 - 1988)
    Last Post: 12-09-2007, 10:31 AM
  3. bonnet cable
    By zohpm in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 14-04-2007, 04:12 PM
  4. bonnet cable broken please help
    By jolea682 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 12-01-2007, 05:16 PM
  5. broken bonnet cable????
    By PaRaDoX in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-09-2006, 07:56 PM
