Results 1 to 7 of 7
Thread: De-tuned memcal Q. (greenfoam!)
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Default De-tuned memcal Q. (greenfoam!)
    Jesus Christ, greenfoam. Your message box is full
    I guess I'll pop the question in public then. Here's a direct quote from the message I just tried to send you
    "Seeing as you're the man with the brains around here, I thought I'd throw you a curveball. I've been reading around a bit about chip burning etc, and seem to recall you (or someone else?) saying something about the possibility of running a leaner setup on the old commodore, to save fuel at the sacrifice of power.
    As far as a daily driver goes, I'm not too fussed about 15kw here or there, so is it actually a realistic option to have a custom de-tuned chip that will provide real gains in fuel consumption? Perhaps an extra 100km per tank (i'm getting around 450km atm).
    Perhaps you know of someone/where that can experiment and create such a chip for a price?"
    Hope you or someone else can shed some light on this for me, or just tell me I'm dreaming so I can stop thinking about it.
    The 1972 HQ Kingswood
    pandaman's Avatar
    pandaman is offline Aussie Muscle Fan
    VN Berlina 5.0 A4
    Feb 2006
    Problem with runnning too lean is that it will run hot and possibly ping, which on a v6 will cause it to pull timing. VR onwards (might have been late VP as well?) came with a lean cruise mode that leaned mixtures out under highway conditions where cooling is plentiful and the motor isn't working too hard. A couple of people have used a modified VR program (greenfoam included) with the lean cruise and a couple of other bits and pieces left enabled. Apparently it can give quite good results if you're doing a lot of highway k's. I'd be very careful about creating a fuel map that's intentionally lean across the board.
    Beau Duke: Man, I'm never gonna get outta this car again. I'm gonna live in it, I'm gonna eat in it and I'm gonna make sweet love to it!
    Luke Duke: You mean you're gonna make sweet love IN it.
    Beau Duke: Oh no, I'm gonna have sex with it.
    VP Executive R-spec
    Jan 2005
    I've run lean maps before and got over 600ks from a tank with 80% highway driving so you can do it, but it's not a epa friendly thing to do because if you want to have lean mixtures everywhere all the time instead of only during a steady cruise with the vr map.
    You need run the mixtures above 14.7 in a really big area which makes the cat converter not work and makes pollution :P in the old days that's how good cars were tuned but now they tune them to use 14.7:1 even though technically it should be 16-17:1. You make much less pollution at 14.7:1 than 17 thanks to the cat so they decided it's better to waste some fuel than make more pollution. Race cars are setup to run higher/leaner than 14.7:1 under light loads.
    It doesn't cost you any power to do that since you still run the normal fuel in the areas where your foot is heavy.
    Either way you are much better off with lpg
    Morton's Avatar
    May 2006
    Cheers for the info panda and foam. It's food for thought... Perhaps running something similar to the vr economy map would be good, because half my ks are freeway transit to/from work. I'm assuming that if I ask around in the right places, someone would be able to create such a map on my chip (or even better, a fresh chip) for around $200-300? HoZy is selling a few memcals...
    I'd like to look into a D.I.Y. chip burn, but I've read the guides, and I don't think I have the time to learn+practice it thoroughly enough.
    VP Executive R-spec
    Jan 2005
    Yeah, follow the smoke and rubber until you find a fast gold vp or ask dr bob as they are local (it might take a couple burns to make it smooooth on your car)
    xcop5l's Avatar
    xcop5l is offline 4th year spanner spinner
    VN ex cop 5L
    Jun 2006
    ol' geelong vic
    id say go for gas i get about 420kms out of an 80ltr tank on the highway and ive got a v8
    Stato on the inside, berlina on the out side,5ltr under the bonnet,stockies all round...........that thing has to be a sleeper
    MY RIDES
    [SIGPIC][/SIGPIC]
    http://forums.justcommodores.com.au/...ad.php?t=41837
    Jun 2005
    Quote Originally Posted by greenfoam
    hahaha fast gold vp....i wonder who that is
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
  1. Owners of Kalmaker Tuned Vehicles
    By shaggerz in forum V6 Development And Modification
    Last Post: 26-09-2011, 10:02 PM
  2. Got My Car Tuned
    By Apeman69 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-11-2007, 02:25 AM
  3. just for greenfoam
    By kniever in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-02-2007, 10:02 PM
  4. Dyno Tuned Gen3
    By enhancedss in forum VY Holden Commodore (2002 - 2004)
    Last Post: 12-07-2005, 11:05 PM
