Page 1 of 2 12 LastLast
Results 1 to 25 of 34
Thread: carbon clean/injector clean
    xcop5l's Avatar
    xcop5l is offline 4th year spanner spinner
    VN ex cop 5L
    Jun 2006
    ol' geelong vic
    Default carbon clean/injector clean
    ok yesterday i did a motor vac on my vn and it made a heap fo difference
    ill explane what a motor vac is for those ot you who havent herd if it befor
    basicly its a machine that we hook up to the fuel rail and run a mix of fuel and a special cleaning agent threw your engine
    it cleans your injectors, the fuel rails, the carbon off the back/front of your valves and valve seats and the top of your pistons.
    and i think it actually worked
    it idles better and has more power and picks up revs quicker
    from the cars ive used it on at work it seems to work best on cars with a few ks on the clock
    mines done about 200.000 and it has made a noticabile difference
    dont worry this is not an ad
    but i recomend getting it done
    theres only 2 in geelong and im not sure where the others are
    but i cant get over the difference it made
    Stato on the inside, berlina on the out side,5ltr under the bonnet,stockies all round...........that thing has to be a sleeper
    MY RIDES
    [SIGPIC][/SIGPIC]
    http://forums.justcommodores.com.au/...ad.php?t=41837
    HATER VP Guest
    Yes I know what you are using. There are a few different systems out there and heaps of different names. What brand chemical are you using?
    I also reccomend this every 40,000 km or 2 years as it is well worth the money.
    VX II Calais L67
    Dec 2005
    PaRaDoX's Avatar
    PaRaDoX is offline boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    anton1o's Avatar
    anton1o is offline [GMHVN6]
    VN 6 Berlina '90
    Jan 2005
    West Subs,Melbourne
    Pricing would be good.
    ride; [GMHVN6] Project Streeter - VN Berlina '90 mods; 65mm throttle-body / Cold Air Intake / 8mm Ignition Leads / Exhaust
    future; Extractors , Cam currently; 101.2rwkw mission; 110rwkw
    xcop5l's Avatar
    VN ex cop 5L
    Jun 2006
    ol' geelong vic
    i think we charge about $180 but im not sure
    the chemical we use is called carbon clean you can only get it from petroject
    MY RIDES
    [SIGPIC][/SIGPIC]
    HATER VP Guest
    We use Chem-Tune chemicals and charge about the same price. I swear by the stuff.
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    Hrmmm, very interesting. All this does is wuna make me spend more money on my car!
    vq rat's Avatar
    vq rat is offline vq rat
    vn bt1 burnout weapon
    Mar 2006
    hamilton vic
    I work as a subaru tec and we use a genuine subaru product called upper engine cleaner, cos the subaru motor is a boxer motor that lay flat the bottom sides of the valves get alot of carbon build up(cos the fuel we get now days is that s#*t it leves the motors very dirty inside and customers not reving there car passed 3500rpm)which we srapy in to the inlet manifold when the motor is running it cleans the top of the pistons ,back of the valves ,in the inlet manifold it brings it up like new ,the valves seal propley again, it remove the carbon on the piston so there is less knocking when cold , it is very suprising when you see how much smoke comes out the back when you give it a few revs , you can tell how revs there ride and who drive like a nan
    xcop5l's Avatar
    VN ex cop 5L
    Jun 2006
    ol' geelong vic
    yeah we use that at work on the subies 2 but only the subies. the motor vac cleans the injectors and rail aswell
    i recon its the best way to do it
    it clears up stumbly idles and gives u more power so its win win
    MY RIDES
    [SIGPIC][/SIGPIC]
    anton1o's Avatar
    VN 6 Berlina '90
    Jan 2005
    West Subs,Melbourne
    hmmph i think i mite get this done, my engines click 230 and this does sound very good.
    Is this called a 'Motor Vac Injector Clean' ?
    HATER VP Guest
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    Can you list the deferent names it may come under? Is Motor Vac short for Motor Vacuum?
    knowledge_is_power's Avatar
    knowledge_is_power is offline Quest for Cognition
    VT SII V6 A4
    Oct 2004
    Nth Brisbane
    Holden sell a product called top engine cleaner. Just stick it in your fuel. I use it about once every 10000kms and swear by the stuff.
  15. #15
    anton1o's Avatar
    VN 6 Berlina '90
    Jan 2005
    West Subs,Melbourne
    Hrmm whats the price of that knowledge_is_power, and yeah proper name's i dont wana walk into a mechanic and look like a dipshit.. Or get the wrong thing done lol
  16. #16
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    Quote Originally Posted by anton1o
    I second that notion.
  17. #17
    VT SII V6 A4
    Oct 2004
    Nth Brisbane
    I get trade price so I'm unsure as to what it is retail is, but I think it should be around $16. The proper name is "Holden Top Engine Cleaner". If your worried give your nearest Holden spares department a call and ask to see if its in stock and the price.
    Its easy to use. Grab a set of needle nosed pliers. Purchase top engine cleaner from Holden. Run the car down till about 1/4 of a tank. Go to a petrol station with your newly purchased metal bottle of Holden Top Engine Cleaner. Unscrew lid, take out safety cap with pliers, poor Top Engine Cleaner down fuel filler and put 15L of petrol in to wash the filler neck and mix the cleaner with your fuel. Drive the car until its about to run out of fuel.
    You will notice the car becoming more responsive as you drive. It even says on the sticker liquid NOS.
    Jezz
  18. #18
    xcop5l's Avatar
    VN ex cop 5L
    Jun 2006
    ol' geelong vic
    that stuff is like the injector clean you put in your fuel tank and it dosent work aswell.ive tryed it not as happy coz the power ran out after the after the fuel did
    our machine at work is called a moror vac also known as a carbon clean or injector clean
    MY RIDES
    [SIGPIC][/SIGPIC]
  19. #19
    VX II Calais L67
    Dec 2005
    Sounds like injector cleaner to me. How does an engine vac compare to using engine flush.. that stuff that you put in the oil, run for a bit and then drop the oil and put new oil in.
  20. #20
    xcop5l's Avatar
    VN ex cop 5L
    Jun 2006
    ol' geelong vic
    that stuff cleans your oil system
    injector cleaner cleans the fuel system and the top of the pistons
    MY RIDES
    [SIGPIC][/SIGPIC]
  21. #21
    HATER VP Guest
  22. #22
    xcop5l's Avatar
    VN ex cop 5L
    Jun 2006
    ol' geelong vic
    this is what we use
    http://www.petroject.com.au/efiserv.html
    just more info to ponder
    MY RIDES
    [SIGPIC][/SIGPIC]
  23. #23
    HATER VP Guest
  24. #24
    HATER VP Guest
  25. #25
    xcop5l's Avatar
    VN ex cop 5L
    Jun 2006
    ol' geelong vic
    seems that way
    prob the same machine with the same chemical but in different packaging
    MY RIDES
    [SIGPIC][/SIGPIC]
  1. best way to clean??
    By VZHSV in forum General
    Last Post: 03-10-2007, 06:44 PM
  2. Injector clean...
    By boojak87 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-02-2007, 08:08 PM
  3. Clean 95 Vs
    By Ghost79 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-10-2006, 01:01 AM
  4. How to clean t/b
    By coolvxss in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-05-2006, 09:32 PM
  5. F/S: Very clean 93 VR
    By Shifty1 in forum Parts And Other Items For Sale
    Last Post: 02-05-2006, 02:12 PM
